Gravity Dropper Tur...
[Closed] Gravity Dropper Turbo - servicing questions
Your experiences please...
My seat post no longer locks into the top position so it currently unusable - which is a shame!
It's got to the point where I think the cable needs changing - has anybody done this? Is it a standard gear or brakes inner and outer? Or is it a specialist part that I need to order from the manufacturer?
Does anybody have contact details for the manufacturer? I would be happy to send it off for a full service if this is offered but I can't seem to find any contact details for a UK based company despite plenty of Googling.
Your help and support would be much appreciated in this matter.
Posted : 09/08/2017 12:32 pm
Standard gear cable, it's quite easy but you need a teeny Allen key.
Bushings wear after a while, but very easy & cheap to do a home service, they last for years....
I think skyline cycles are UK service agent.
Or you can get gd on the states to sort it out
Posted : 09/08/2017 12:43 pm
It's a standard cable (can't remember which though).
They are an absolute doddle to service yourself. Google it, there's plenty of how-to's online.
The key bit is the collar on the top of the lower bit of the post; you have to tighten it [I]just[/I] right to make sure it locks properly at the top an bottom of the stroke.
Posted : 09/08/2017 12:44 pm
GD's are comically simple to work on thanks to being 200 year old technology. If the pin isn't holding it in the top position it may well just be that you need to adjust the top collar, which screws on and can loosen with use (edit- as above but I was googling links at the same time ๐Ÿ˜‰ )
Chain Reaction carried service kits, inside the post there's 2 slider blocks a bush that sits at the top, then the top collar with a seal, and that's pretty much it. I have the non-remote version so can't comment on the cable but the rest of the post is the same. It may be that CRC/Hotlines have stopped importing them? I've heard good things about GD dealing direct but you have shipping costs etc to contend with
http://gravitydropper.com/products/turbo-parts/
Posted : 09/08/2017 12:53 pm
As above, have a fiddle with the collar. Lots of good diagrams etc on the GD website on taking the post apart. Rest in the knowledge once serviced it'll quite a while until you need to do it again
Posted : 09/08/2017 1:02 pm
As above. Unless the cable has snapped it would most likely be the collar that needs a little tweek.
Posted : 09/08/2017 1:14 pm
As above, the cable is just a standard gear cable. If you do replace it, be VERY careful with the grubscrew at the lever end. If you overtighten it, you'll wreck the lever.
However, it's probably not the cable, it's probably the collar, as others have said. Try loosening that gradually and see if the post will lock in the top position.
Also, it's a good idea to remove the inner post, clean it, and check that it's not bent or cracked. Then lube it and adjust the collar until it works properly.
Posted : 09/08/2017 1:17 pm
Thanks all, I tried the collar adjustment as suggested and it has solved the problem!
Is this a sign that something is wearing/ needs replacing shortly? The said collar is now very loose and will probably move around a bit - will this cause other components to wear more quickly?
Thanks again for all your feedback.
Kind Regards,
Dave
Posted : 09/08/2017 3:04 pm
[I]Is this a sign that something is wearing/ needs replacing shortly?[/I]
Not particularly (there's not really much in them to wear out). Saying that, a strip down, clean and grease wouldn't go amiss.
Posted : 09/08/2017 3:13 pm
One of mine is like that - I just wrapped a few layers of PTFE tape round the threads before screwing the collar on. That sorted it.
Posted : 09/08/2017 3:21 pm
Good tip Andy R, thanks again all.
Posted : 09/08/2017 4:26 pm
My GD won't lock in the bottom position, same as above ?
Posted : 25/08/2017 7:51 pm
Yes. Best to remove the inner post and inspect to make sure it's not bent or cracked. Clean and lube it lightly, then reassemble. Tighten the collar just enough that it will lock in the down position.
Posted : 25/08/2017 11:06 pm
Probably, if I remember right it needs tightened if its not locking down, loosened if its not locking up and just balance between the two.
Yeah, and tbh it only goes in 2 directions so just fanny about with it til it works.
It's worth servicing them though- the main shaft will wear and go graunchy and eventually cause you lots of bother. Taking it apart, cleaning it, greasing it and rebuilding it is really easy and worthwhile to make your bits last
Posted : 25/08/2017 11:54 pm
It's worth checking the rubber concertina cover. It should sit in a groove round the top of the seatpost. If it isn't this can stop the post locking in the bottom position.
And from an old email:
Here is a link to my order page of commonly purchased parts.
http://gravitydropper.com/category/common-parts/
I will get them in the mail to you as soon as I receive your order.
Sincerely,
Kim Sicz
Gravitydropper Seatpost - 37938 Mission Vista Drive - Polson, MT 59860
tel: 406.883.3555 - email: sales@gravitydropper.com - website: www.gravitydropper.com
www.facebook.com/GravityDropper www.twitter.com/GravityDropper
Posted : 26/08/2017 6:35 am
thanks all , will give it a try .
Posted : 26/08/2017 7:00 am
I did some maintenance to my GD on Saturday.
Top tip: spray some lube into the lever triangle area. Everything sweet as - and no need to change the cable. ๐Ÿ™‚
Posted : 28/08/2017 8:43 pm
