Morning all
On the way home after a bike packing trip in the Atlas Mountains (highly recommended).
On day one the seat stay on my Arkose 3 failed. Morocco being the place it is meant I was able to get it 'fixed'. I'm pleased to say it lasted the rest of the trip.
I doubt I'm in a position to make a warranty claim (bought in 2020 before Evans was taken over).
Looking for a replacement frame and fork that will take 2x11 and a minimum of 45mm tyres (bolt through).
Cheers.
If I ever replace my gravel bike frame it will be with one of these:
https://www.aliexpress.com/item/1005004671491800.htm
Note: That may not be the cheapest, it's just the first one that came up when I searched.
Alternatively:
https://www.aliexpress.com/item/1005005678330464.htm
https://www.aliexpress.com/item/1005009252609372.html
I'm going to go with the tried and tested method of suggesting both what I own and what I desire. And that is a Kinesis Tripster ATR (own) and a Fairlight Secan (want).
I have a secan, only a couple of rides so far but it's a very nice thing to ride.
Other option I looked at was a Ti Camino but decided I wanted something closer to an all road bike rather than closer to a rigid mountain bike which I already have. It's really a replacement for my Giant Defy but far more capable off road without feeling sluggish on the road
Can't recommend a Fustle Causeway enough. Absolutely love mine
https://www.ridefustle.com/products/causeway-gr-1-5-emerald-green
Worth asking - I think they had a Limited Lifetime warranty then, if not it may have been 7 years (can't remember now). Either way, SD may honour that.
Edit. Now I can repost a day later without doing anything!
I really like my Mondince FM326 which is a Chinese open mould frame "inspired" by the Mondraker Arid. If I had the cash I'd have bought a Santa Cruz Stigmata but this is as close as I could find geometry wise.
The Causeway 1 frames, if they're your size, are keenly priced for aluminium. Otherwise, in the Arkose ballpark, and in alu: Kinesis Tripster AT? In steel, I'd immediately think about a Fairlight Secan or Brother Mehteh.
Good to see you're still on here Jameso. Just got home and have checked the paperwork - 'limited lifetime warranty' for the frame.
What does that mean in real life? The bike is just over six years old. I'll drop into the local Evans and see what they say.
Thanks for all the suggestions - some really nice options out there, especially the Secan. Unfortunately its loaded weight limit (rider + luggage) of 115 kg is a bit close to my max set up.
I'm ideally looking for something more affordable.
The Causeway was a strong contender, until I noticed the push fit BB (I should have said, ideally I'd like a BSA 68mm BB).
I've always fancied a Kinesis - the AT looks like what I'm after but is more that I was hoping to spend.
I was expecting lots of love for the Sonder Camino. Seems to tick a lot of boxes. Any red flags I should be aware of?
PS - Weren't Bird planning a gravel bike? The only reference I can find is a page saying it was going to be launched last year.
It's been on hold. According to Ben, some moving of the goalposts from the factory about minimum order quantities. But, according to their socials today (or possibly yesterday), sounds like a V2 Aerolon is on its way sometime this summer.
I had a previous generation Camino and loved it, did 3,000 miles without missing a beat and only changed for something different. That said the newest ones are going to feel very different to your arkose - much longer (as is the fustle, which is what I have but I see you don’t want press fit) and I’d imagine a fair bit slacker.
The Faran limit is 125kg for rider and 25kg for luggage. Same geometry but 631/4130 tubing and steel forks
The secan sure looks lovely. It was high on my list recently but went with a Camino ti partly because I could get a better build kit for the same money and partly because the ti finish looks fresh pretty much indefinitely, regardless of how much you abuse it with bags strapped to it etc. I probably would have slightly preferred the more road leaning geo of the secan but I'm not disappointed in the Camino at all..feels absolutely fine to me on the road and a great all-round gravel and adventure rig.
Also, might be worth considering a full bike on c2w rather than just a frame? ( Depending on your situation, obvs)
You may be able to get a full bike at probably not much, if any, additional cost to you vs. just getting a frame.
Also it was rumoured to be getting the chop at the last budget so may be some of the last chances to take advantage.
I have a Faran and other than it being a slightly rubbish colour I absolutely love it. Run 700 x 44 or 650 x 50ish and its great with both.
Limited there means limited to reasonable use within the natural lifespan of a frame that will fatigue at some point, no manufacturing defect failures within that reasonable lifespan. i.e don't expect a warranty on a 15+ year old frame as it's done well to last that long under regular use but if it's clearly not been used much in that time, it should be considered. I don't really like the term bc it's open-ended but 'lifetime warranty sells'. If they do consider it (old co. Vs new co. might be the main thing) at just over 6 years old it might come down to whether it's looking hammered or looked after.
Good idea and one I considered. Alas, my employer (public sector) follows the rules to the letter and will expect me to evidence that the bike has been used "mainly for qualifying journeys". It's also the Cycle2Work (Halfords) scheme which limits who I can buy from. 🙁
I'm going to drop into my local store this morning to see what they say.
It's done ~4,500 miles and has been ridden as intended, but it's still a great looking bike. I'll update.
Merlin have close to 25% of the GX Race at the moment.
https://www.merlincycles.com/kinesis-gx-race-gravel-frameset-272795.html
There's 33% off a Tripster AT but only in 60cm.
After saying the AT was out of my preferred price range, I've found a F&F in the right size (I think - I need to understand the differences in stack and reach) which is nicely discounted.
Cross post - that's the one I spotted. 🙂
My Camino is fine although definitely a bit mountain bikey to my mind but I moved to that from an On One Dirty Disco. A mate who just bought a Camino reckons it is nicer than his older Reilly. I bought a Felt Breed as a winter road bike , partly because of price and also because it seemed a bit more nippy than the Camino.
Silly money off a full build in your size too!
https://www.merlincycles.com/kinesis-tripster-at-grx-820-2x12-gravel-bike-336758.html
A mate of mine has ordered a BXT gravel frame, mainly as it's quite an aggressive geometry. Just got some nice 30mm carbon ali-express hoops for it. He's a bit of an ali-express addict.
STOP! That is a hard deal to overlook and no c2W faff. Top of the list if Evans don't come good. 😀
I've been to the local Evans - the store manager took the necessary details and is passing it to head office for a decision. 🤞
I've heard back from Evans - 'out of warranty'. They've offered 10% off a complete bike as a goodwill gesture.
I'd go with the Tripster in that case. Literally the only bike I'd ditch mine for is a Secan, and I'd probably keep the frame just in case.
2nd this, there's a sale on frameset and complete bikes too.
https://ukgravelco.com/fustle-causeway-gr1-review/
Thanks again for all the input and suggestions.
I've whittled the options down to a Camino, Tripster AT or Causeway.
The Tripster AT geometry looks very close to the Arkose. The other two look more 'aggressive' with lower bar positions and their head angles are clearly in a different league.
I'd welcome any thoughts/observations on the differences - comparison table.
What evidence have you got to go with that? I work for a County Council and I've never been asked a peep about a bike on C2W once the voucher/order has been issued... Never heard of anyone having to prove anything ever before either. I doubt any public sector workplace has the capacity nor the interest in doing this.
