Gravel bike or CX b...
[Closed] Gravel bike or CX bike? What's the difference?
Been out the game for a bit - what is the difference??
Posted : 21/10/2018 7:46 pm
 JoB
geometry, tyre clearance, weight, bottle mounts and about £300
Posted : 21/10/2018 7:50 pm
CX is for racing and needs tyres no wider than 32mm. Comfort isn't a consideration.
Gravel/adventure is what most folk actually want. Wider tyres, more relaxed angles, comfort. Might even have rack mounts.
Posted : 21/10/2018 7:54 pm
What Jo B said - but a couple of years back before gravel became a thing then 'cyclocross' bikes would often have rack mounts, bottle mounts, and all the accoutrements of what is now called a gravel.
A true CX is stripped down for 60 mins of effort around a muddy field, nothing more that it needs.
Posted : 21/10/2018 7:57 pm
All above gravel bikes are better on the road between tracks where the cross bike is better off-road not that much between them generally the gravel bike is heavier.
Posted : 21/10/2018 8:05 pm
Whys that then?
Posted : 21/10/2018 8:10 pm
Uh oh. Now you've done it. 15 pages and a ban, I reckon. Biscuit anyone?
 ton
both are not as good as a true touring bike, which is as capable and has been as capable for many many years.
Posted : 21/10/2018 8:13 pm
Touring bike doesn’t sound cool tho 😂
Posted : 21/10/2018 8:29 pm
Depends on the Gravel bike (and the touring bike).
In general gravel bikes originate from the USA where they have a network of unpaved roads to ride/race on. So started off as pseudo-CX bikes with less mud clearance and angles closer to a road bike. Now they've gone the other way and tend to have bigger tyres (<45mm) and more relaxed angles.
There's also slightly more burly variations like the salsa fargo and vaya. Genesis vagabond etc which are designed to take 29er wheels and tyres.
Then there's 650b gravel bikes which take MTB tyres, but keep them more compact (closer to CX wheel diameter).
Just been for  CX/gravel clubrun, whilst I like my CX bike I took the rigid 29er, I was slower up hills (I would have been anyway tbh) but was way ahead on anything even slightly uneven (ie a mildly rutted green lane or patch of gravel).
Posted : 21/10/2018 8:35 pm
Well I find the cross bike has a shorter top tube so is sharper in turning and handling off road and is slightly shorter in height much better in mud the gravel bike has a longer wheelbase that's what I find between my two 52cm Treks one cross one gravel.
Posted : 21/10/2018 8:36 pm
In Reading?
So like the opposite of what makes modern mtb's good handlers?
Posted : 21/10/2018 10:34 pm
In reality, very little. Unless you are picking a bike from the extreme ends of the bell curve.
Also, in reality a high end gravel or cx bike serves perfectly well as a road bike too.
You can talk about B.B. drop, stack height and reach but the differences are usually minor.
N+1 marketing
Posted : 21/10/2018 10:43 pm
gravel - slacker head angle, more bottle mounts, room for bigger tyres.
cx- less sloping top tube to aid shouldering
see also racing gravel e.g. warbird & long distance bike packing/adventure gravel e.g. tripster AT
Posted : 21/10/2018 10:52 pm
N+1 marketing
Agreed, there's not much in it when you get down to the realities of riding them. I raced my CAADX today 50 mins breathing out my aris yet it has rack, bottle mounts, and I can ride it all day in comfort. It's a very different proposition to a head down XC MTB race machine, where you'd really not fancy more than a couple of hours on one, CX bikes are fundamentally comfy.
Probably the tires are the one unequivocal difference-maker - 40mm + rubber is a signfiicant change and I guess won't fit in most cross bikes.
Posted : 21/10/2018 11:05 pm
In Reading
Yes.........
(Squints suspiciously and wonders who's rumbled me)
I'll give you a clue, I was the one that looked like I was from STW.
Posted : 21/10/2018 11:07 pm
I went from a Ridley X-bow (definitely CX) to a Tripster AT (definitely gravel) and the difference is very noticable.
Fatter tyres, slacker head angle and flared drops make the AT far more versatile off road than the X-bow was. There's nothing I've ridden on the AT that the X-Bow couldn't cope with, but the AT makes it much more enjoyable (for me).
Posted : 21/10/2018 11:12 pm
Yes, there are fairly minor but they do add up.  15mm higher BB, 2 degrees on head tube, shorter top tube etc,.
I ride a track bike off road which is probably closer to a CX bike than a gravel bike (higher BB, steeper head tube etc,.) and it does feel a bit less stable than gravel bikes I have tried.
Doesn't feel any less comfortable though as comfort and handling are two different things.  Comfort for me is a bike that fits really well and that can be a track bike or a mountain bike.
Posted : 22/10/2018 7:42 am
Probably the tires are the one unequivocal difference-maker – 40mm + rubber is a signfiicant change and I guess won’t fit in most cross bikes.
This is true, I’ve fitted 38-40mm rubber on a cross bike but that would be the limit.
I’ve also done a 400k audax on one though, change of wheels, move a few spacers, add a brooks  and it was comfy for 14 hours of riding
Posted : 22/10/2018 8:10 am
Fatter tyres, slacker head angle and flared drops make the AT far more versatile off road than the X-bow was. There’s nothing I’ve ridden on the AT that the X-Bow couldn’t cope with, but the AT makes it much more enjoyable (for me).
two of the three things you have reference there are component changes though.  Everyone can put flared drops in their bike and a lot can whack 38cm tubeless on with no issues.
Posted : 22/10/2018 8:28 am
I’ll give you a clue, I was the one that looked like I was from STW.
Beard, green gloves 😉
Posted : 22/10/2018 8:40 am
Beard - tick
Rigid - tick
Single speed - tick
SSUK race plate still in spokes in blatant violation of the rules - tick
Suggesting pub stop rather than cafe - tick
Posted : 22/10/2018 8:47 am
That's not really true though, fitting fatter tyres is dependant on the frame, and the point several other posters have made is that a racing CX frame is usually designed to take narrower tyres, as evidenced by the number of people struggling with mud clearance on CX frames with 33s at the Scottish CX series. Edit: didn't read your post properly, you've sort of hinted at this anyway.
I also wouldn't be comparing either type of bike to a true touring bike. I had a Salsa Vaya which by all accounts isn't even a heavy duty tourer. Much as I wanted to love the bike, when I wasn't using it as a tourer it was just heavy, dead and slow steering, not really what you want in a CX bike OR a gravel bike, which to me are supposed to be just road bikes designed for looser surfaces.
I race CX (badly, slowly) and would be happiest on a gravel bike, it'd still handle better than the 29er I'm racing at the moment, but retain the decent tyre clearance. Problem is, £ for £, gravel bikes seem heavier than CX bikes, not sure why that is, probably the new marketing uplift mentioned above...
Posted : 22/10/2018 9:08 am
So... if you had a cross bike that you one used on gravel rides (is there such a thing?) would it then be a gravel bike? Or still be a cross bike? Mine's called an 'Adventure Tour Race' bike, so has all bases covered. Except commuting, which is what I use it for mostly...
Posted : 22/10/2018 11:07 am
I expect things like rack mounts, mudguard mounts, bottle cage mountain x3 all cost a bit of money and so the bike gets specced down and heavier as a results. Also a cross bike is a focussed race bike so weight is a key selling point whereas the average gravel bike rider could be buying a lighter road bike but they're not so weight is not a prime consideration, comfort maybe more important.
Posted : 22/10/2018 11:38 am
The term gravel bike is an adventure in terminology which will bring out the pedants and the nay sayers. 🙂
To me a gravel bike is basically a bike suitable for covering distance on natural terrain and roads.
I agree with ton in that it's a cross between a touring bike and an mtb without the optimisations for technical riding such as suspension but with wide tyres, and with its control set up for long distances on road, so likely to be dropbar.
CX bikes are almost right but their clearances are way too small, and genuine ones are not designed for long day comfort.
It's the sort of bike that always has been available with a bit of bodging, but it's good to see it get its own niche because we will get some development on the genre.
I like gravel bikes. 🙂
Posted : 22/10/2018 11:48 am
I agree with ton in that it’s a cross between a touring bike and an mtb
Aren't classic touring bikes more heavily built than the modern 'gravel' bike?  To cope with being loaded up?  That's not to say you couldn't tour on a gravel bike of course.
if you had a cross bike that you one used on gravel rides (is there such a thing?) would it then be a gravel bike? Or still be a cross bike? Mine’s called an ‘Adventure Tour Race’ bike, so has all bases covered
Ah but in the US they have gravel races as well as CX races...!
Posted : 22/10/2018 11:57 am
Ah but in the US they have gravel races as well as CX races…!
As they do in the UK. Often with catchy names like "Grinduro"
Posted : 22/10/2018 12:07 pm
Aren’t classic touring bikes more heavily built than the modern ‘gravel’ bike?  To cope with being loaded up?  That’s not to say you couldn’t tour on a gravel bike of course.
Depends on the touring bike, one* came out on Sunday and didn't cope as soon as we turned off the road.
The problem is a "touring" bike is anything from a winter/audax style road bike with pannier mounts for B&B hopping. To a Surly Troll, or even an Ice Cream Truck if your tour is going off grid in Alaska.
Then a gravel bike is anything from a gravel racing bike from the USA with skinny tyres, naff all clearance and no superfluous braze ons, to a Salsa Fargo with 27.5x3" tyres.
There's probably more overlap between what's described as a "gravel" bike and a "touring" bike than there are bikes that sit far enough outside the overlap. Not many touring bikes that wouldn't handle at least some unpaved roads, and not many gravel bikes aimed at racing without mudguard eyes and somewhere to mount luggage. If you walked into a shop and said "I want a gravel bike" they could sell you almost anything, from a CX bike to a MTB.
*of the old skool dawes galaxy variety
Posted : 22/10/2018 12:17 pm
To be fair, my Gravel bike is my Touring bike, but then a version of it was also sold as a Cross bike too.
I rather like the invention of the Gravel term as it does try to differentiate between race and non-race types. Too many folk bought Cross bikes for commuting when they didn't really want once but there was no good descriptor.
Posted : 22/10/2018 12:25 pm
Of course you can tour on anything - I'm talking about shop labels.
Posted : 22/10/2018 12:36 pm
thisisnotaspoon
Depends on the touring bike, one* came out on Sunday and didn’t cope as soon as we turned off the road...
I'd take one of those anywhere I could take a gravel bike.
In fact I've been keeping and eye out for a cheap Galaxy 531ST frame so I don't ding my lightweight lugged 531c bike doing that sort of thing.
Posted : 22/10/2018 12:56 pm
If you walked into a shop and said “I want a gravel bike” they could sell you almost anything, from a CX bike to a MTB.
A shop that hasn't kept up with the times yes.  If you came to my shop I and asked for a gravel bike I would offer you a range of gravel bikes and they wouldn't be CX (but could be close) but would definitely be nowhere near an MTB.
If however you came in and asked for a bike that could be used to ride on gravel then the conversation would be different as I could offer you a CX bike, a gravel bike, an MTB and so on.
If you want to visit my shop just look out for "Pedantic cycles"
Posted : 22/10/2018 1:13 pm
I’d take one of those anywhere I could take a gravel bike.
In fact I’ve been keeping and eye out for a cheap Galaxy 531ST frame so I don’t ding my lightweight lugged 531c bike doing that sort of thing.
Could read that either way. Either you're under using your gravel bike of over using the tourer!
I've ridden one down the trail in question too, but with the best will in the world even with CX tyres it wasn't an appropriate bike and it turns a fast flowy 3minute bit of singletrack with the occasional jump into a 10-15 minute faffy puncture risking stressful slippery rooted nightmare. It's the sort of trail that a well ridden CX/Gravel bike wouldn't lose much time on Vs an averagely skilled MTB but that's where the fun Vs appropriateness balance tips IME, you can make something more challenging and therefore more fun upto a point, then it just becomes risky and slow.
I've got CX, MTB and fat bikes to choose from, and recently sold the 531st tourer (and still have a road bike). On an average chilterns "XC" loop though the speed difference between the off road bikes was negligible. The CX (aka gravel) bike will climb a smidgen quicker, and is definitely quicker on the road, but all that's immediately lost as soon as the speed picks up off road.
Posted : 22/10/2018 1:43 pm
I'm with Scotroutes on this one; if you're not actually racing, then you develop the bike that best fits the type of gravel or touring that you do.  For me, it's a flat barred Croix de Fer CX frame, with a triple chainset and light-ish wheels that are currently wearing 40mm tubeless.  It has toured in the Alps on standard 32mm road slicks and frequently does big days across Scotland, like last Saturday in the rain:- Dundee to Kyle of Lochalsh.  This was using roads, a fair bit of NC7 grit trail, disused old A9 sections and then up and over the Corrieyairick before A82 & 87 to Kintail.  Comfortable all day, quick up climbs and competent on mild off-road, it works for most things and it's compromises and occasional adjustments work for me.  Although I did find a couple of occasions on that trip when a snorkel would have been handy....
Posted : 22/10/2018 1:56 pm
A Croix de Fer isn't a CX bike is it?
Posted : 22/10/2018 2:02 pm
A Croix de Fer isn’t a CX bike is it?
Well it's either named after the pass in the Alps and it's a lightweight climbing bike, or it's a steel cross bike that happens to share it's name with an alpine pass? Whichever way it's probably wrong to someone, it's a moderately tubby CX bike (albeit a very "gravel" orientated one for the pedants), or a tourer.
Hence there's barely a fag paper between the definitions of tourer/gravel/CX in a lot of cases. If people don't believe me, go down to an actual CX race and see the menagerie of bikes that are raced, there's everything from Fat bikes to road bikes if it's dry (and probably a lot of "gravel" bikes)!
Posted : 22/10/2018 2:09 pm
That’s not really true though, fitting fatter tyres is dependant on the frame, and the point several other posters have made is that a racing CX frame is usually designed to take narrower tyres, as evidenced by the number of people struggling with mud clearance on CX frames with 33s at the Scottish CX series. Edit: didn’t read your post properly, you’ve sort of hinted at this anyway.
I also wouldn’t be comparing either type of bike to a true touring bike. I had a Salsa Vaya which by all accounts isn’t even a heavy duty tourer. Much as I wanted to love the bike, when I wasn’t using it as a tourer it was just heavy, dead and slow steering, not really what you want in a CX bike OR a gravel bike, which to me are supposed to be just road bikes designed for looser surfaces.
I race CX (badly, slowly) and would be happiest on a gravel bike, it’d still handle better than the 29er I’m racing at the moment, but retain the decent tyre clearance. Problem is, £ for £, gravel bikes seem heavier than CX bikes, not sure why that is, probably the new marketing uplift mentioned above…
Previously I had a Merida CX500, raced CX on it with 33's and also did the Dirty Reiver twice on 38 g ones with no issues and no lack of comfort.
I've now got a Marin Cortina CX - full carbon, ultegra hydros etc.. I run gravelking Sk's on one set of wheels and 28c road tyres on another. in road form I've done 400k audaxes and 100k training rides with the local club and it will be doing the DR next year.
I've no issue with 'gravel' bikes in principle, but as someone who has done a 'lot' of gravel riding I've yet to find a Cx bike lacking, with the caveat that I've never tried out 50c tyres on a drop barred bike.
In terms of true touring, rack mounts etc. that's another misnomer I think. Everyone is going for soft luggage anyway which you can whack on to anything
Posted : 22/10/2018 2:15 pm
Is the answer marketing?
Posted : 22/10/2018 2:37 pm
I dunno about marketing - didn't the marketeers adopt it after the riders (or magazines) had decided it was to be called "gravel". (Shame the name gnarmac didn't stick,  as invented by a STWer 😀 )
Posted : 22/10/2018 2:43 pm
It’s the sort of bike that always has been available with a bit of bodging, but it’s good to see it get its own niche because we will get some development on the genre.
Pretty much this. I'd have killed for the current crop of gravel bikes when I used to live in loughborough- plenty of routes that were too much road to really be fun on the mtb, but enough nice off road to be worth being able to.
I'm not sure how much difference there is really though outside of the super specialist CX race or drop bar MTB type of bikes- my Bowman was probably in relatively early for the current gravel trend and has a lot of the same features (longer, slacker, bigger tyres clearance) but it was still designed as a CX bike. Just a CX bike for how the designers were riding it, out and about in the woods as well as racing. So I suppose in a rambling way I'm suggesting that it's down to intent?
Posted : 22/10/2018 3:05 pm
 Nico
If you want to visit my shop just look out for “Pedantic cycles”
What goes around comes around.
I want to ride on mountains. What sort of bike should I be looking for? (These mountains have some roads on them, and some gravel, for futher info).
Posted : 22/10/2018 4:00 pm
Welcome sir, have you had a nice day so far?  Yes, parking is a nightmare isn't it.
So you want to ride on a mix of rocky/rough ground, road and gravel.  What sort of % do you typically spend in those areas
Oh, 80% gravel and 10% between the other two you say.  In that case if you are happy to compromise on the rocky, rougher terrain then I would suggest a gravel bike.
Great, that is a good choice.  Do you want me to wrap it or will you ride it home.
Posted : 22/10/2018 4:32 pm
two of the three things you have reference there are component changes though.  Everyone can put flared drops in their bike and a lot can whack 38mm tubeless on with no issues.
If I'd put 38mm tyres in my Ridley I wouldn't have got to the end of the street on it.
Anyway, it's cool that there are lots of similar bikes to choose from, as long as you know what you're looking for.
Posted : 22/10/2018 10:17 pm
I’ve put flared drops on my Ridley X-bow. Is it still a cross bike?
Posted : 22/10/2018 11:06 pm
It's a cravel bike. Or cyclogross. If you put some bikepacking kit and a 130mm fork you could call it Gnardventuro+.
Posted : 22/10/2018 11:13 pm
IF you want it to be, then yes.
Posted : 22/10/2018 11:19 pm
Cross? It's probably effin livid!
Posted : 22/10/2018 11:28 pm
thisisnotaspoon
...Could read that either way. Either you’re under using your gravel bike of over using the tourer!
Motto, any bike, anywhere.
If there's an interesting looking track and I'm on a bike, there's a good chance I'll take a punt along it regardless of suitability of the bike. I want to see what's at the other end or along the way.
I suppose you could call me a gravel tourer... 🙂
Posted : 22/10/2018 11:55 pm
Now here comes a story that’s never been told......They're all just bikes.
Posted : 23/10/2018 12:33 am
If there’s an interesting looking track and I’m on a bike, there’s a good chance I’ll take a punt along it regardless of suitability of the bike.
Good motto and one I have applied.  All of the people I see riding around the New Forest on road bikes are really missing out by not heading up one of the many gravel roads or track but they would dare try it on their 'road' bike.
Posted : 23/10/2018 7:46 am
Good motto and one I have applied.  All of the people I see riding around the New Forest on road bikes are really missing out by not heading up one of the many gravel roads or track but they would dare try it on their ‘road’ bike.
Been there done that, trashed an expensive pair of road pedals in the mud.
Well it was Yorkshire rather than a suburb of London which didn't help.
Posted : 23/10/2018 12:49 pm
Not sure why riding along gravel roads on road pedals would damage them even in the London suburb of the New Forest.
Posted : 23/10/2018 1:19 pm
Because unlike mtb pedals with steel cleats they're made of plastic, which lasts about half a mile before the little tabs have worn of the front and back of the cleat when exposed to mud.
Posted : 23/10/2018 1:22 pm
Really it depends if the CX bike was actually a CX bike intended for racing or something designed to be £999 for c2w purposes and never expected to be more than transport.  Both are equally valid bikes incidentally, just different. There are ‘cx’ bikes that blur the lines because they’re not really meant for race use
As above, the CX will be shorter, steeper and more aggressive with no need for anything bigger than mid 30’s tyre wise and will probably prioritise shoulder carrying under the TT.  Cables will thus never be routed there.  It’s an angry bike for 60 muddy minutes.  Gravel bikes have a much less rigid design spec and may make better everyday bikes.  Of course this depends on the person, I love the rocket-ship feel of my CX and the aggressive/steep doesn’t cause me problems.
I think really it’s about what you want. If you want a comfortable bike that will go softroading, look at Gravel first. If you prize sprint performance over longride comfort or plan to race cross at some point then CX.
Posted : 23/10/2018 1:25 pm
wait - did you just write 'softroading'? Is that a thing? Has anyone launched a clothing brand for it yet?
Posted : 23/10/2018 2:49 pm
Quick, contact Rapha!!!
Posted : 23/10/2018 5:16 pm
Rapha? Ha! No credibility for corporate sell-outs in the nascent Softroad scene. Softroaders follow a different path to the Rapha clones. A gritty, slightly compliant path. A path (just imagine there's some kind of folktronica backing track  playing over this VO and the video is all kind of lensflarey and authentic) that takes them away from the white lines of the road and (there's probably a campfire shot at this point) and onto the route less travelled. Softroad - it's The Way Of Life. (close to logo and wide landscape shot as the rider disappears t'ward the horizon.
Posted : 23/10/2018 6:36 pm
joemmo
... Or cyclogross....
Excellent name!
I immediately envisaged a cx bike with fat 650B wheels.
Now I will have to build a cyclogross bike so I can be a cool kid*. 🙂
*Yeah, I know, that'll never happen. My daughter made it clear.
Posted : 23/10/2018 6:37 pm
Does "gravel bike" actually sound cool? I doubt a duller name could have been found for the genre, even if everyone had tried really, really hard.
Posted : 23/10/2018 6:50 pm
I recently created the following utility website for finding and comparing gravel bikes:
http://www.gravel-bikes.co.uk/
You may (or may not) find it useful.
The site doesn't include any CX bikes though. In my opinion these are race bikes specifically for competing in CX events.
Posted : 26/10/2018 12:59 pm
The site doesn’t include any CX bikes though. In my opinion these are race bikes specifically for competing in CX events.
Yet you include bikes like the cannondale synapse? that's not anywhere close to a gravel bike, certain way less so than most CX bikes.
ETA: this is how Giant describe their TCX 'cross' bike
Move up through the field in heated cyclocross battles, or go long on gravel road epics. With a superlight ALUXX SLR aluminum frame, matched with a composite fork and front and rear thru-axles, the TCX SLR gives you smooth, confident handling on all types of terrain. New flat-mount disc-brake technology provides added control on tight CX courses or wide-open dirt road descents. Symmetrical chainstays add pedaling stiffness, and the D-Fuse seatpost helps smooth out rough terrain.
Posted : 26/10/2018 1:19 pm
I was watching the highlights of the CH CX (Bern?) on TV last night and noted a few riding with bottles and cages
Going soft?
(this is i think practice but there definitely were)
A mistake by Van Aert and Mathieu van der Poel attacked. 2018 World Cup Bern. © E. Hausmesser / Cyclocross Magazine
Posted : 26/10/2018 1:31 pm
 aP
It may be that the temperature was reasonably high, but not high enough to allow drinks from support (under UCI rules). Hand-ups aren't allowed in cx so in order to get a bottle a rider must come into the pits, change bikes and exit with a new bike with a water bottle attached in some manner.
Almost all modern CX bikes now come with water bottle bosses, when I went up to be measured in '95 for my islabike cx bike I should have asked for bottle mounts but didn't and I've rather regretted it ever since, My carbon argon18 Arsenic has bottle cage mounts. I think I shall go out on my islabike tomorrow, with gravel tyres obvs, for riding gravel/ tow path and tarmac (oh and Feltham goods marshalling yard motorcross tracks).
Posted : 26/10/2018 2:01 pm
