GPX files are a pai...
GPX files are a pain to work with..... How to join two?
Say I had 2 GPX files, one's a line that goes from home to a town, the other is a loop starting from the end of the first line...
What would you use to join them together to make 1 long lollipop route?
I use OSMandMaps on my phone / ipad which I think will do it but I really want to do it on a proper computer, using a mouse so I can tweak bits around easily.
Is there something online I can do it with? Ride With GPS might do it I think, but I don't want to pay for another subscription. OS Maps doesn't let you join 2 together.
Cheers!
Posted : 17/06/2023 7:09 pm
Houns reacted
Garmin Basecamp.
Posted : 17/06/2023 7:15 pm
leffeboy and phil5556 reacted
https://gotoes.org/strava/Combine_GPX_TCX_FIT_Files.php
Ignore the "strava" aspect; pretty sure it'l do what you want
Posted : 17/06/2023 7:18 pm
spooky_b329 reacted
Can you just redraw it at https://www.bikehike.co.uk/mapview.php
Always my go to for drawing/creating gpx routes
Posted : 17/06/2023 8:04 pm
Open them both in a text editor then cut and paste the relevant bits together?
Posted : 17/06/2023 8:22 pm
thenorthwind reacted
This, assuming you don't actually want to change the routes at all.
Posted : 17/06/2023 8:25 pm
Another vote for gotoes, used it a few times
Posted : 17/06/2023 8:26 pm
Join them using a text editor, open them in whatever mapping software you normally use and edit as normal then.
Posted : 17/06/2023 8:27 pm
I've used Viking GPS for years. https://sourceforge.net/projects/viking/
Posted : 17/06/2023 8:28 pm
Gpx studio. Great website
Posted : 17/06/2023 8:29 pm
phil5556 reacted
Thanks. Scotroutes first suggestion has done the job, I forget that I have basecamp. Routes tweaked, joined and I can now split them back in to 3.
And then I'll export them in to OS Maps for a final sanity check before trying to follow them ๐Ÿ™‚
I do usually just redraw stuff but it's 300km in Kent, so isn't as straight forward as what I usually play with.
Posted : 17/06/2023 8:49 pm
scotroutes reacted
Oooh, this looks good too cheers!
Posted : 17/06/2023 8:52 pm
