Does anyone have a GPX Editor? I'm really struggling to do a task and trying to avoid having to manually cut up a .txt file.
I have a GPX track of 32,000 points that is 1100km long. I need to split it up into 4 GPX files say 8000 points each as my gps will only allow tracks to be loaded/displayed of up to 10,000 points.
Is anyone able to do this for me if I send the file?
C
Basecamp will do it in an eaxy-to-use visual format. It's a free download. Give it a go but if you're struggling then I can do it for you.
Hi Scotroutes,
I do have basecamp but couldn't work out how to do it. I know it's lazy but could you do it for me? I'm running out of time and need to get it done?
C
Email in profile
email sent. Thank you v much in anticipation
C
Chris Basecamp will also reduce the number of points via an optimisation algorithm - from memory its an option when you right-click on the track. You can do it multiple times, obviously you lose accuracy but imo its good enough for following a route
It's easy enough to do in bikehike, but if Colin's helped you out then it's a bit late.
INCOMING!!!!!
