i have a Kona Unit and at present am running it singlespeed. I am now finding that it is too spinny on the flats and want to have a 1x9 setup to cover more distance.
My Kona has horizontal dropouts.............what do i need to be able to attach the rear mech?
Alfine hub?
i already have the rear mech and cassette so am just looking at how to fit it all together.
Alfine or move to somewhere with hills. 😉
or If theres no r mech hanger you need to weld one on or get some "slidable" adjustable dropouts
edit it has a mech hanger. what are you struggling with
There is no mech hanger on the current frame.
Can anyone point me in the direction of where i can purchase some slidable adjustable dropouts to attach rear mech?
Is there not a versio of the SLX rear mech that hangs from the wheel bolt?
i already have a sram mech that i need to fit so want to try and use that.
DMR makes a chain tug with mech hanger. see [url= http://www.dmrbikes.com/?Section=products&pageType=item&category=8&CategoryName=Frame%20Parts&itemid=FPCTMH ]here[/url]
A Hone hub/rear mech might work as the rear mech hangs off the axle rather than a mech hanger. I'm not sure if the angle of the horzontal dropout will work with it though.
Kona make geared sliding dropouts with a hanger for their Explosif, Cowan and Unit bikes, all of which are interchangeable. They are, however expensive (circa £30). Your local Kona dealer should be able to get one
If your unit has sliding dropouts then Pilo from Israel sells them on ebay. Item 130114617356
Not cheap at around £35
Can sell you a hone rear hub and mech im not using, you could build it into a wheel?
As peachos says above, just get a DMR chaintug with mech hanger built in. I have one on my Pompino at the moment and it works just fine.
Hip - does [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=23936 ]this[/url] look to be the same thing?
I've got an Explosif with geared sliders - the ones with the built-in tensioning bolt. If yours is the same (i.e. no hanger but with built in bolt) I'd be happy to swap. Email in profile if you need it.
farticus - thanks for the offer but i want to keep the normal sliders for when i go back to SS in the winter.
OK, but you can use them for SS too - that's what I do, but I've not run gears on it & probably never will.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=249 ]here[/url]
Don't do it...
giantjasonHip - does this look to be the same thing?
Yes. Exact same thing. CRC used to do the original Kona ones for £20 but that was last year and I've not seen any more in stock since.
