Going from a 6 degr...
[Closed] Going from a 6 degree to a zero degree rise stem, will I notice a difference?
Thinking of chopping in my 90mm 6 degree rise for a 70mm zero degree rise.
Has anyone done this and will a 6 deg difference really be noticable?
On my current set up I've got a 3mm spacer above my stem, so I could always place that below the stem to take into account the 6 deg drop in rise to keep my bars at the same height couldn't I?
Posted : 07/05/2013 3:04 pm
My quick reckoning is that it should drop the height down by around 9mm and closer to you by just under 20mm (unsurprisingly given that the stem is 20mm shorter). I think you will probably be able to notice the difference.
Posted : 07/05/2013 3:16 pm
But you won't die!
Posted : 07/05/2013 3:44 pm
[i]But you won't die![/i]
I think that's the key issue here I wanted some reassurance on!
Posted : 07/05/2013 4:18 pm
You [b]will[/b] die.But I don't think it will attributable to the change in stem length
Posted : 07/05/2013 4:20 pm
[i]You will die.But I don't think it will attributable to the change in stem length[/i]
That I can live with, so long as its not anytime soon. But will I notice it ๐Ÿ™‚
On a more serious note is knocking 6 deg rise off on a new stem really going to stuff up my handling or is it negligible?
Posted : 07/05/2013 4:30 pm
