Go-Pro headset top ...
Go-Pro headset top cap mounts - what's good?
I fancied trying one of these as a sort of 'best of both worlds' between a chesty mount and an out-front mount.
I had some good results with the out-front mount, especially on relatively slow twisty singletrack when I was really leaning the bike in and out of corners (something the chesty doesn't seem to capture as well), it looked great on screen. Just wondering if a headset top cap mount would achieve the same effect but incorporating the bars at either side to frame the shot.
I was hoping for one with a bit of rearward extension but the only one I've seen (which is co-incidentally the cheapest) looks a bit agricultural, it doesn't have the captive Go-Pro 'nut' so looks like you'd need a wee spanner every time you wanted to remove or adjust the camera?
https://www.sjscycles.co.uk/accessories/mwave-qrir-top-ahead-cap/
Posted : 31/10/2023 2:07 pm
I think I've got one you could have somewhere if you're not in a tearing hurry.
It's just vertical mind (backward shifting it would find my knees very quickly, I think that one you linked should go forward over a - ve angled stem)
Posted : 31/10/2023 2:13 pm
Can you not just reverse your out front mount so it points backwards? Some you can position over the stem by doing that.
Posted : 31/10/2023 2:14 pm
think I’ve got one you could have somewhere if you’re not in a tearing hurry
Yes please! Will ping you a message 👍
Ha! Good idea, hadn't thought of that 😎 Would preclude using Garmin (out front anyway) but I had already assumed I would be removing it so as not to obscure the shot, can mount it on top tube or something for navigation duties.
Posted : 31/10/2023 2:58 pm
