giant reign and coi...
[Closed] giant reign and coil shock
hello
anyone here on reign with coil ? what is recommended sag for reign ?
my weight 87kg with all gear.
Posted : 30/01/2017 11:22 pm
Yoann runs around 30 percent sag on the back, if I remember correctly the 425lb to 450lb springs that he uses would give him 27-30 percent sag based on his weight. I did the calculation a while back though, so I can't remember.
The trick with the Reign is to have a progressive compression shim stack tune, so the compression hardens up deeper into the travel.
Posted : 31/01/2017 12:44 am
is that how he had his shock tuned ? the progresive shimstack ?
Posted : 01/02/2017 11:55 pm
Just set your shock up like a really fast Pro rider, that will be exactly how you want it ๐Ÿ˜‰
Trust me I've had a world champs winning fork in my hands and me (as a mere mortal) would not want anywhere near those settings. Don't just copy someone you need to think about what you want it to do/feel like.
Posted : 02/02/2017 12:03 am
Yeah, he had it tuned progressively.
Wiggles, good point, but the Reign can be a little soggy on the rear due to the leverage ratio. My advice, get a coil, ride it - get it tuned if you don't like something about it, or get a Fox RC4 with a bottom out adjuster.
Posted : 02/02/2017 12:09 am
I didn't mean to criticize your advice obviously the kinematics of the frame are important to work this out and you are correct in what you said. I mean you need to know what you want as an individual rather than going "I want an EWS top 10 racer set-up please"
Also be aware that having you shock tuned usually requires you asking for specific traits/changes rather than just asking for a tune for certain bike as the person doing it won't know the leverage curve of every bike available....
Posted : 02/02/2017 12:19 am
Precisely wiggles, get a stock shock, ride it - if there is anything specific you dislike - start noting your thoughts down and have specific changes made.
I'll probably be putting a coil on my Reign....
Posted : 02/02/2017 12:23 am
I DO HAVE CURRENTLY FOX RC4 ON MY REIGN WITH 450 LB COIL WHICH GIVES ME 29% SAG CURRENTLY ( standing on pedals). THE BIKE FEELS VERY PLUSH , ALTHOUGH I WILL TRY 500 COIL AND DECIDE THEN , AS UPHILLS ARE RATHER PAINFULL AFTER 2 HOURS OF RIDING. the shock has unknown shimstack setup as i purchased it from ebay about 6 months ago. i see that to bottom out reign it takes 1600N which is rather conservative leverage design compared to 2500N+ like on patrol or capra.. i will probably adjust bottom out adjuster if i am not happy with stiffer coil
ahh sorry for caps..
Posted : 02/02/2017 2:40 am
