Giant Overdrive 2 /...
[Closed] Giant Overdrive 2 / Fox 34 - 1 &1/4 steerer tube*** HELP NEEDED ***
Good day, I need advise.
I have a 2014 Fox 650b Tallas 34 that i am taking out of a Giant Trance 650b bike. It has the 1 & 1/4 Steerer tube. How can i get this to fit on other bikes other than Giants with overdrive 2?
Without sending to Mojo and getting the steerer, crown, stanchions swopped..
Posted : 08/01/2014 9:04 pm
You just need to change the top cup I believe.. ZS44 top should do the trick..
"The bike's head tube inner diameter actually remains the same, at least on Giant's bikes. This means that not only can all of Giant's bikes that come equipped with the OverDrive 2 system be easily converted to fit a standard tapered fork and stem, but older models from previous years can also be converted to accept a new OverDrive 2 steerer equipped fork. "
http://www.pinkbike.com/news/Giant-OverDrive-2-Steerer-tube-sizing-2011.html
Posted : 08/01/2014 9:27 pm
Don't think the top cup has anything to do with it, it's just the inner diameter of the top bearing is 1.25" rather than 1.125"
Posted : 08/01/2014 10:05 pm
Thank you guys...
How do i get the fork that comes out the Giant to fit in other frames?
Posted : 09/01/2014 10:43 am
You need a frame that takes the same size headset as a Giant frame, then swap the headset over..
And the stem..
Posted : 09/01/2014 10:47 am
Any frame with a 44mm straight headtube will take the giant overdrive forks.
My mate fitted his to a Cotic Solaris with just a change of the top bearing & cap
Posted : 09/01/2014 10:56 am
@steve_b77 .. Can you please check with your friend what Top bearing assembly he bought. The exact spec and where did he get it from?
Posted : 09/01/2014 2:07 pm
