Giant OD2 Headset u...
[Closed] Giant OD2 Headset upper bearing change to run normal tapered fork?
From memory the OD2 headset uses smaller bearings in the top race and that if you replace it with a 'normal'  sized set you can run normal tapered forks?
Yes/no....
Thanks.
Posted : 27/09/2018 11:18 am
 sv
It's actually larger but yes you can change it and run a normal tapered steerer.
Posted : 27/09/2018 12:49 pm
On mine I needed to replace the cup (semi integrated) as well as the bearing, split ring and top cap.
From memory it was cheaper to buy a comple FSA (Giant branded) headset from JE James than just the top.
Posted : 27/09/2018 1:27 pm
Ok thanks chaps.
Posted : 27/09/2018 11:39 pm
I bought a mix and match Hope headset and got my lbs to fit it.  I’ll see if I can dig out the details.
Posted : 28/09/2018 8:27 am
Cheers.
If I go down the route of changing the headsets I might try a WC or Superstar angle set ones.
Posted : 28/09/2018 4:52 pm
I thought it was OD that was special and Giant abandoned this in OD2 ???
Posted : 28/09/2018 4:59 pm
Not sure but think they dropped the OD2 a few years ago? Bit out of touch with this sort of stuff.
Anyway mines this year https://www.giant-bicycles.com/us/anthem-x-advanced-29er-1-2013
Posted : 28/09/2018 11:59 pm
If a fork is the issue I have an OD2 fox 100mm you can have for free, just cover the postage.
Posted : 29/09/2018 7:59 am
I have a 2015 ... OD2
https://www.giant-bicycles.com/gb/xtc-advanced-27dot5-1-2015
The headset/bearings are standard 1 1/8 - 1 1/2 ... FSA Orbit Headset...
I haven't swapped forks over but I'm pretty convinced you could... have you actually tried?
Posted : 29/09/2018 9:43 am
 elma
Kryton 57 I'm desperate to find some 11/4 forks sorry to butt in but i'll take the forks off your hands if they are available.
I'll PM you as well.
Posted : 29/09/2018 1:49 pm
Yeah the forks are 1"1/4 - 1"1/2
Posted : 29/09/2018 1:58 pm
