Giant Anthem X2 - ...
[Closed] Giant Anthem X2 - fitting a tapered fork possible??
As above, does a lower cup exist, that enables a tapered fork to be run with a 2009 Giant Anthem?
I've looked on the Cane Creek site, but it gives no options....
Posted : 17/10/2012 8:55 am
I thought tapered headtube started in 2011 on the Anthem?
Posted : 17/10/2012 9:56 am
You cannot fit a tapered fork in a non-tapered frame (unless it's a 1.5" non-tapered frame).
Posted : 17/10/2012 9:58 am
I'm guessing that because the older Anthem has the 44mm head tube (integrated headset) you're thinking maybe a larger external cup could be utilized to take the taper at the bottom and the normal integrated cup at the top?
Unfortunately I don't know the answer to this, but I would be interested to find out
Posted : 17/10/2012 10:10 am
You can fit a tapered fork in to non-tapered headtube > done it on my Scott Spark! What do you , require, however, is an adapter cup, such as the Hope H cup.
And I need to find out if there's an adapter cup that fits a 2009 Anthem.... The Hope H cup that I've used previously, won't fit an Anthem.
Posted : 17/10/2012 10:26 am
And having just looked at the Hope headset guide as well, doesn't look like it's possible to buy/fit an adaptor 1.5" lower cup to the 2009 Anthem, as it is 'Integrated' type...
Posted : 17/10/2012 10:38 am
Nope, don't think you'll be able to do that with your fancy integrated headset, but your Anthem handles great with a normal, straight steerer, and the integrated headset look cool.
Happy days!
Posted : 18/10/2012 3:20 pm
Are you selling that HOpe H cup?
Posted : 01/11/2012 9:10 am
