Giant Anthem suspen...
[Closed] Giant Anthem suspension bearings...where from?
Hi all, there is a slight bit of play developed in the two small bearings that are pressed into the rear triangle connecting to the top rocker link.
It looks an easy enough job to tap them out and press in some new ones ๐Ÿ˜•
Just had a look on CRC and they have a vast selection of bearings, so does anyone know what size I should be looking for, any recommendations etc.
It's a 2008 Anthem not the Anthem X, if that makes a differance.
Thanks
Posted : 15/04/2010 6:54 pm
Try here buddy....... [url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=62&Name=Giant+Replacement+Bearing+kits ]Giant bearings[/url] and if you just want a couple of bearings, get the number off the bearing case and go to this area [url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=107&Name=Sealed+Bearings ]"clicky"[/url] and select the right ones
Posted : 15/04/2010 7:14 pm
Itheisinger, cheers.
Posted : 15/04/2010 7:57 pm
Aye, all bearings have a code on the side, so go to a proper bearings place (industrial estate or online) and get them that way. Or buy 'em off Kaesae. ๐Ÿ˜€
Posted : 15/04/2010 8:46 pm
