Looking at building the above bit interested to know if anyone has one and what. Max tyre clearance is. I know recommended is 35mm.
Ed
(carbon one?) I've got one - very recently; first remotely proper ride today
I have 33s on fairly wide rims (xc mtb wheels) that come up to 36.4 at the back. Loads of room
Do you think you could get a set of 40s in or would it be tòo tight? What do you think of the bike?
You'd get a 40 in easy - whether it'd wear the frame when mucky, dunno but I'd happily give it a go
Thanks for the pics and info. Massive help 🙂
Your tyre is out of level there scaredypants. I'd get that checked.
You’d fit a 40 in easy I reckon. I’m running 35mm g ones & there’s loads of clearance to go wider
Your tyre is out of level there scaredypants. I’d get that checked.
Rubbish ! The bubble's perfectly visible on at least one side. Do you even DIY, bro ?
