which if any chain tugs fit a genesis IO rear droput? Ive had it with the monkey metal grub screws supplied with it!
Thanks
+1 with the same issue. How the hell do those grub screws bend??
i think it gets dragged round the thread and bends, ive heard people using surly tugnuts and dmr's chain tug. just wanted to see which ones work before i buy
Think the idea is you use them to tension the wheel, tighten it up then back them off slightly
(i.e. don't ride with them under tension)
If you want a cheap and easy solution I got a bag of about 15 bolts from B and Q that work fine for 3 quid. Tighten up with a flat head screwdriver too so easy to sort...
Do you have access to a workshop and proper tooling, perchance?
That one doesn't look as if you used a hacksaw and molegrips to make it.
