gemini pivot bearin...
[Closed] gemini pivot bearings - where to get?
Anyone changed the pivot bearings on a gemini recently? The LBS has them on order but it's been over a month. Any ideas on where they can be sourced online?
Posted : 06/09/2009 6:15 pm
Any bearings place really. simplybearings.co.uk near Wigan are good. You just need the code off the old ones.
Posted : 06/09/2009 6:26 pm
They're sealed cartridges Rickos, I was thinking you needed to just swap the cartridges for new ones - would I be able to open them up and replace the ball bearings inside - how do you get the old bearings out? It's not something I've done before.
Posted : 06/09/2009 6:52 pm
press out old bearings (whole cartridge) and press in new cartidge
Posted : 06/09/2009 6:54 pm
You need to press the old bearings out (complete) and press new ones in. Ideally use a proper bearing press, but it can be done with a big bolt, some washers and a lot of care.
BETD for the bearings, the code is 6902 2RS Max
Posted : 06/09/2009 6:56 pm
Thanks all for the advice, new set ordered from BETD ๐Ÿ™‚
Posted : 06/09/2009 8:29 pm
