Gears not shifting
[Closed] Gears not shifting
My gears go up the cassette but not down.
I have oiled up my cables,adjusted absolutely eveything even changed mechs.
Still no joy and I have a ride planned for sunday!!!
Posted : 17/09/2010 12:50 pm
I'd [u]change [/u]the cables.
APF
Posted : 17/09/2010 12:51 pm
Best upgrade you can make ^^^^^^^^^^^
Fit new inner and outer cables ๐Ÿ™‚
Posted : 17/09/2010 12:57 pm
Yep. Odds on you need new inner and outer cables. Go for full lenght outhers if you can! ๐Ÿ™‚
Posted : 17/09/2010 12:59 pm
new cables + 1
drill out the cable stops and fit full length outers plus cable oilers + 1
Posted : 17/09/2010 1:15 pm
as above, new cables would be my first thought as it's easy. Failing that, I'd consider whether the mech hanger is straight.
Posted : 17/09/2010 1:16 pm
If it won't shift down to the smaller cogs then there's too much friction in the system. Assuming you have a High Normal mech. If it's a SRAM mech make sure the length of outer that bends round to the rear mech is correct.
As others have said change not only the cables but the outers too - they corrode inside and cause massive friction.
A bent mech hanger won't help either but will affect general shifting not just one way.
Posted : 17/09/2010 1:27 pm
