Ive been running a 32f ring with 36r on a 1x10 setup but tbh I spin out too easily on the trails around here so I've put on a 34f and a 38r. In practice I cant really tell the difference when using the easiest combination of front and rear gears but is there any difference?
What do the maths say?
For climbing am I better off with 32x36 or 34x38 or even 34x40?
Thanks Naffa
You are spinning out - presumably on the 11T - means you need a bigger chainring.
If you need lower gears - for climbing - then a larger cassette and/or a smaller chainring.
bikecalc.com is your friend...
Thanks for the direction to bikecalc. If Ive used it correctly ive calculated that using 26"x2.1" wheel/tyre combo a 38fx34r gives me the same distance per revolution as 36fx32r = 23.4"
