Gearing changes fol...
[Closed] Gearing changes following C2C - Advice required please
 dst
I thought I would pose this question on here so the STW collective could give some sage advice.
I have just completed the C2C (the road one) on my Tricross . I managed to ride everything but only just, the climb out of Rookhope nearly giving me a coronary.
I am fairly lardy and was carrying all my kit in panniers. Current set up is a double with 48 / 34 up front and a 12 - 27 cassette when the hills got really steep I felt that I needed a granny ring just to let my cadence up. Then I had another thought.......
The rear mech meeds replacing anyway, so if I put on something with a longer cage on (XT perhaps) could I run a MTB cassette say 11-34 or 11-36?
Will that work or am I mad?
Is there a good website that explains all this stuff?
How do I work out what Cage length (medium or Long) required?
Any answers appreciated
My son says I should just 'Man-up'!
Dave
Posted : 24/09/2012 11:17 am
I did the same route on my Boardman CX Pro but didn't have panniers on. I did it in two days and stayed in a B&B. I didn't struggle with gearing but that could be down to the difference in weight we were carrying.
To answer your question though yes that'll work. You'll need a long cage mech as its got to take the chain on very small gears and the larger cogs. Any mtb long(er) cage mech will do
Posted : 24/09/2012 1:05 pm
Should work, I'd have thought you'd need a long cage mech and a new chain.
But are you going to need such low gears again?
Posted : 24/09/2012 1:09 pm
 dst
Thanks Gents
I think I will do it, or something similar again.
Re the weight, I am 15 stone and not sure of the Pannier weight but I had 30 litres loaded up with clothes etc. I also used B@B but took three days.
I am not fit enough (yet) to do it in two!
Posted : 24/09/2012 1:19 pm
 dst
Subsequently found this and thought it was good
[url= http://sheldonbrown.com/deakins/lowgears.html ][/url]
Posted : 24/09/2012 2:20 pm
How about another crankset for touring? A 26/36 double perhaps? Should be possible if you can move your front mech down a bit...
I did that C2C recently and dropped down a chainring size in preparation for some loaded climbing.
Posted : 24/09/2012 4:36 pm
 TomB
my road bike got an xt mech and 34 tooth cassette (52/39 chainset)on it when I moved to the lakes, worked fine, big jumps but gives you the low gearing you're after.
Posted : 24/09/2012 4:39 pm
 dst
Thanks all
Posted : 25/09/2012 9:49 am
I did this last week to the CX bike I use for my commute (compact chainset). I used a 9 spd Deore mech, 11-36 cassette & a new chain (didn't actually measure the old one to see if I could reuse theat but thought it best with a new cassette).
I had been meaning to do it for ages (and I now wish I had since it works perfectly!) Hills are now a breeze if I am feeling lazy & slow (even with loaded panniers).
As well as the extra low gears I suppose I now have one slightly bigger gear as well! Definitely worth the slight extra weight IMHO.
Posted : 25/09/2012 10:36 am
 dst
Thanks zilog.
I am going to do it.
Posted : 25/09/2012 8:43 pm
