I've seen a bike on this forum with neat rubber "anti-chafe" fittings on the gear cable housing. These have been positioned near the headset. They were tapered, being thicker at the ends, if that helps with the description. Does anyone know where I can get these from? I've googled but without success...
Here ya go...
http://www.chainreactioncycles.com/sram-outer-cable-frame-protector-4-pack/rp-prod85922
Thanks teasel, just what I was thinking of; not cheap mind you! Been looking in the "cables" rather than "frame protection" sections!!
An alternative is something like an old drinks bladder tube or similar. Slice down the middle, work over the cable and you're done. Camelbak tubing isn't quite as grippy as the Sram things but a visit to a local hose supplier might produce something more suitable.
I use sugru to make hose protectors. Works brilliantly and a pack makes about 3 so better value than the Sram things.
http://www.amazon.co.uk/gp/aw/d/B007VXJM58/ref=mp_s_a_1_3?qid=1397067668&sr=8-3&pi=AC_SX110_SY165
There are also [url= http://www.wiggle.co.uk/bbb-bcb-90d-gear-cablewrap-frame-protectors/ ]these[/url] ones from Wiggle which are slightly cheaper than the SRAM ones.
I run them on my bikes and I've found them to be really good.
They also have them for your [url= http://www.wiggle.co.uk/bbb-bcb-90b-brake-cablewrap-frame-protectors/ ]brake[/url] hoses as well.
Some good suggestions here, hadn't thought of sugru, but could be a good option. Don't know about you lot, but the problem I have is the head badge on my frame cutting into the cables. I currently wrap insulation tape around the cable but these noodles seem to be the way forward. Thanks.
I have some of what you're looking for and jagwire make them, got a set with my ripcord gear cables, quite tough to find otherwise.
you can also use rubber wiring grommets which cost pence.
How do they work? Surely the protector touches the frame instead of the cable, so it'll still rub?
Nothing works as well as this:
[url= https://farm3.staticflickr.com/2739/4270548301_d022438915_b.jp g" target="_blank">https://farm3.staticflickr.com/2739/4270548301_d022438915_b.jp g"/> [/img][/url]
[url= https://www.flickr.com/photos/peter_atkin/4270548301/ ]Yeti_575_038[/url] by [url= https://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
Doesn't work on all bikes, but if it does it's the best solution.
the 'hard' outer casing of gear cables will rub away the paint lots quicker than the 'soft' rubber of the frame protectors - fit them to all my bikes, never had an issue.
Decathlon sell them for very little.
Peterpoddy, what exactly have you got fitted there ?
2 bits of clear tubing slid over the gear outers and secured with a cable tie through them and around the head tube. It depends on your cable routing if it works or not but if it does it's effectively another cable guide and cable rub simply doesn't happen. Those rubber things can move or fall off. This doesn't. 🙂
Decathlon +1. Much cheaper.
