Gash is Conti 5000 ...
[Closed] Gash is Conti 5000 sidewall - repair or leave alone?
Looks like it's on the border of needing fixing, but there's no tube coming out either. Caused a tiny puncture (if I had been running tubeless I probably would have flatted too?).
Leave alone or repair somehow?
If you're running these, definitely avoid rocks and gravel, they cut easily (got a smaller one in the front)
Posted : 02/06/2020 4:38 pm
If you’re running these, definitely avoid rocks and gravel
Road race tyre in not great offroad shocker
I'd bung some superglue in there
Posted : 02/06/2020 8:06 pm
Mine seem fine after today's offroad jaunt (although they are 28mm TL)
https://imgur.com/a/bqmuVTF
Posted : 02/06/2020 8:11 pm
I’ve had similar with a pair of gp4000s2. I know it’s a race tyre but I can’t believe they are so highly regarded for such a fragile tyre. I’ll be trying another brand next time. Puncture repair patch on the inside and superglue in the gap?
Posted : 02/06/2020 8:12 pm
I'd keep riding that and keeping an eye on it.
Super glue has yet to work for me, maybe a patch
Posted : 02/06/2020 8:22 pm
That's not the sidewall.
Posted : 02/06/2020 8:32 pm
Id be wanting that repaired tbh.
High speed blowouts are usually pretty crap.
Posted : 02/06/2020 8:37 pm
That’s not the sidewall.
Good point 🙂
Posted : 02/06/2020 8:46 pm
True. So superglue in the crack plus a patch on the inside, ordered a £2.5 Park tool TB-2 Emergency Tire Boot for the inside, will cut it to size.
@simondbarnes avoid rocks at all cost :S
Posted : 02/06/2020 10:19 pm
I had what looks like exactly the same damage on my GP5000TL. I super glued the outside and patched the inside.
Posted : 03/06/2020 6:58 am
How does superglue work? It’s solid not at all supple so surly cracks with any movement ie using the tyre
Posted : 03/06/2020 7:14 am
If you do glue it/mend it/continue to ride it, make sure it's on the back. A front blowout at speed might be more expensive than a new tyre...
Posted : 03/06/2020 9:16 am
Some people report superglue hardening and puncturing the tire, so either way you probably want an interior patch.
Use shoe glue / seam sealant, takes 24 hrs to set but stays flexible.
I always carry half of one with my spare tube, just in case I have to limp home with a sidewall tear
Posted : 03/06/2020 2:08 pm
Yeah seems like a nice product, don't think regular patches are that good for sidewall tears as they're too elastic.
Posted : 03/06/2020 3:20 pm
When I've used it in the past it just seems to help stop other shit getting in there and causing another puncture
Posted : 03/06/2020 7:16 pm
