Garmin GCS10 on a F...
[Closed] Garmin GCS10 on a Five
[#5274376]
Any one managed to get one fitted and get cadence working?
It doesn't come close to fitting on the non-driver side. I though I'd sorted it by mounting it on drive side. Both speed and cadence worked, but the chain rubbed the speed arm.
It might work if I can mount it upside down under the swing arm on the non-drive side. If only Garmin had designed it flat on the top...
Posted : 24/06/2013 11:47 am
I didn't think cadence was really something very important on a mountain bike - especially something like an Orange 5.
Posted : 24/06/2013 11:59 am
I don't think it is, but I'm curious and it's my only bike
Posted : 24/06/2013 12:55 pm
A Wahoo sensor might give you more options
Posted : 24/06/2013 2:25 pm
Or you can get separate ANT+ speed and cadence sensors, eg from Bontrager.
I think you don't really need a speed sensor, GPS is good enough for that most of the time. So just get a separate cadence sensor.
Posted : 24/06/2013 2:36 pm
[quote=CraigW ]Or you can get separate ANT+ speed and cadence sensors, eg from Bontrager.
If the GCS10 is set up without a magnet on the wheel it only measures cadence anyway. That means relying on GPS for speed/distance. The downsides to that are that it can get a bit lost under (wet) tree cover and it can underestimate your distance slightly.
Posted : 24/06/2013 2:39 pm
That depends on what Garmin you are using. Some will always try to use the speed sensor if it is paired to one. So if you don't have a wheel magnet, it will just display zero for speed.
Other Garmins (eg the Dakota/Etrex) always ignore the speed sensor, and only use GPS for speed.
Posted : 24/06/2013 2:43 pm
Ah - cool. FWIW, my 705 is happy to report distance too.
Posted : 24/06/2013 2:45 pm
Thanks everyone, decided to bin it and rely on GPS
Posted : 26/06/2013 10:03 am
