Garmin Forerunner 3...
[Closed] Garmin Forerunner 305 - Bar Mount.
Anyone brought one of these? looking at 2 options, a rubber clamp and zip ties or a replacement velcro strap and bar fitting.
Are they any good or should I just leave on my wrist? Do they fit oversize bars ie 31.8
Posted : 03/02/2011 10:18 am
 cp
I use a bit of foam pipe lagging, which works a treat - just strap the rubber watch strap round it.
Posted : 03/02/2011 10:21 am
Similarly, anyone know somewhere that sells the Edge 705 mounts for cheaps? They're a tiny piece of moulded plastic with holes for zip-ties, yet I've not seen one for less than £30. I need two, but not at that price!
Posted : 03/02/2011 10:31 am
I use the
Means I got the bike mount on 1 bike and the 'wrist' mount on the other (over some old light mount I had lying around) and it takes seconds to swap the unit over. The bar mount works with oversize bars. I've never had a problem with in in around 3 years.
£15 is crazy crazy money for it tho!
#Edit: This one: http://www.wiggle.co.uk/garmin-wrist-and-bike-mount-forerunner-305/
Posted : 03/02/2011 10:49 am
[url= http://www.parker-international.co.uk/9590/Garmin-Bike-Mount.html?referrer=froogle&utm_source=google&utm_medium=froogle&utm_campaign=pid9590 ][/url]
Is this the mount you're after paul?
Posted : 03/02/2011 10:56 am
I've got the rubber clamp 305 mount. You don't need to use the cable ties on 31.8mm bars as it tightens up with the unit's strap anyway. It might be a little loose with ties on 25.4mm bars unless you're careful but I haven't had any problems with either.
It's a bit cheaper than the velcro one but I must admit a bit of pipe lagging would probably do the job just as well!
Posted : 03/02/2011 11:33 am
Yeah, nice one! Cheers
Posted : 03/02/2011 11:49 am
I've got tyhe velcro/bar-mount for mine and it's fine. It uses cable ties round the bars so it's no problem fitting it to any size of bars.
Posted : 03/02/2011 12:25 pm
