Garmin Edge 800 and...
[Closed] Garmin Edge 800 and Anquet maps
Never had a problem with my gpsmap 60, but now I have an edge 800 I can't transfer routes from my pc to my gps. Contacted Anquet and they suggested saving the files as gpx rather than adf but that still won't work. When I connect to the pc I can see the files are on the gps but it just won't open them. Any ideas???
Posted : 17/05/2013 2:07 pm
Are you putting them in the right place?
its all on here, cause i can't explain it
http://frank.kinlan.co.uk/garmin-edge-800/dummies-guide-to-the-garmin-edge-800/
Posted : 17/05/2013 2:10 pm
You have to copy gpx tcx files etc into the new files folder on the edge 800 and not the courses folder as you might expect it then finds them and puts them into the courses folder..i know its mental
Posted : 17/05/2013 2:12 pm
Stufive. Brilliant it works but wtf should it go in there lol. The old one was a lot more user friendly ๐Ÿ™‚
Posted : 17/05/2013 2:25 pm
๐Ÿ˜€
Posted : 17/05/2013 2:34 pm
Steve Austin, I will check out that guide later, got to be easier to understand than the garmin one ๐Ÿ˜‰
Posted : 17/05/2013 2:39 pm
Stu explained what i know but couldn't explain ๐Ÿ˜€
I have to say, that Garmin have done very little to explain how their product works. It does work very well, but it would be nice to know how it works without guessing everytime you press a button.
Posted : 17/05/2013 2:49 pm
My old 60csx was a lot easier to use..........progress??
Posted : 17/05/2013 6:30 pm
And data from gps to anquet maps?? The gps unit saves my ride as a 'fit' file. Now I can't get it onto my pc, transfers to strava with no problems. Awaiting an answer from dummies guide, but I thought I would try on here too as peeps on here know everything ๐Ÿ˜€
Posted : 19/05/2013 10:22 am
You could use Garmin Basecamp to download tracks from the Edge, then export as a GPX file. Then open that in Anquet.
Or use GPSBabel to convert from FIT to GPX.
Posted : 19/05/2013 1:41 pm
Thanks Craig, will try basecamp, couldn't find fit files on gps babel.
Posted : 19/05/2013 1:46 pm
Double post oops
Posted : 19/05/2013 2:15 pm
