Garmin Edge 520 and...
[Closed] Garmin Edge 520 and iphone (6s plus)
Does anyone have the above combo and managed to get them to work with the Garmin connect iphone app? i can connect the garmin to my phone with bluetooth but when i open the garmin app it cant find it.
Posted : 07/05/2016 9:03 am
Not a Plus but a 6S. Latest firmware/OS on both. Works fine.
What do you mean by 'you can't find it' in the app? Is it listed under 'Garmin devices' in the menu?
[img] ?raw=1[/img]
Posted : 07/05/2016 9:08 am
under devices it says no devices paired, but shows it as being registered to garmin connect
[img]URL= .html[/img]
Posted : 07/05/2016 9:19 am
[img] http://i1259.photobucket.com/albums/ii543/wallahisme/F1DC6911-44C0-457E-9846-C90172D6AD59_zpspapek11a.pn g" target="_blank">http://i1259.photobucket.com/albums/ii543/wallahisme/F1DC6911-44C0-457E-9846-C90172D6AD59_zpspapek11a.pn g"/> [/img]
Posted : 07/05/2016 9:44 am
If you had the garmin paired with a previous phone then you need to delete it from you devices list as this can cause an issue.
Posted : 07/05/2016 9:59 am
Just tried it on my girlfriends phone an iPhone 6 and it worked straight away odd
Posted : 07/05/2016 1:08 pm
You been buying a bike mate?
Posted : 08/05/2016 11:10 am
Works fine with my 25/6S.
Sometimes I have to manually pair the Garmin to the 6S - there is an option on the Garmin menus. Then the app just sorts it out or select Garmin devices on the app.
Check out the yt vids.
Also start a fresh by clearing it from the iPhone Bluetooth settings.
Posted : 08/05/2016 11:27 am
