Garmin edge 205 use...
[Closed] Garmin edge 205 users - help pls
Can i get a route out of it onto memory map? if so - how?
Posted : 11/05/2009 6:01 pm
gps babel, google it
Posted : 11/05/2009 6:02 pm
You can import it straight from the 205 into memory map
Go to GPS>GPS setup and fill that in
Then go import from GPS, choose tracks
Posted : 11/05/2009 6:12 pm
can't seem to do that
Posted : 11/05/2009 6:19 pm
Are the latest USB drivers installed?
I have the opposite problem, when I click to upload a route the 205 beeps instantly and says "transfer complete" but no route is uploaded ๐Ÿ™
Posted : 11/05/2009 6:21 pm
Are you uploading tracks not routes?
They all seem to be stored as tracks on mine, if you upload routes it pretends to upload something but there's nothing there.
Posted : 11/05/2009 6:26 pm
Uploading tracks - it used to work fine but stopped last week ๐Ÿ™
Posted : 11/05/2009 6:29 pm
simonfbarnes - Member
Have you run out of memory on the Edge?
how do you delete waypoints/marks on the dge?
Posted : 11/05/2009 6:30 pm
Navigation...Find...Delete All
Posted : 11/05/2009 6:32 pm
read TFM and now away - cheers
Posted : 11/05/2009 6:33 pm
not as far as I know, I delete each track as soon as I've uploaded it, and have about 10 stored waypoints
Posted : 11/05/2009 6:34 pm
Still can't get tracks OFF the edge 205. Memory map states that "software version 3.20" is not supported ๐Ÿ™
Posted : 30/05/2009 2:57 pm
tracklogs and sportracks both support the 205 and will retrieve recorded tracks from the unit.
Posted : 30/05/2009 3:00 pm
I get that with my 305.
Posted : 30/05/2009 3:01 pm
sorted - using motion based
Posted : 30/05/2009 3:06 pm
How you do that Ralph only just got my 305?
Posted : 30/05/2009 4:33 pm
Create a motion based account and download the client for your pc
http://www.motionbased.com/
when you connect the unit to your laptop open the MB client and awwy ya go
Posted : 30/05/2009 4:41 pm
Ooh that's cool but for some reason it can't find last nights ride, has Monday's though.
Posted : 30/05/2009 5:04 pm
The tracks only become available after they've been "ended". This happens when either you start recording a new one *or* you hold the reset button down for 3 seconds (the unit counts down). Took me a while to work out why the most recent track wasn't being downloaded from the unit. I now press/hold the reset button before downloading.
Posted : 30/05/2009 5:07 pm
No luck just tried them both it picked up the 1 sec lap I just did though. Wonder if there's a problem as seems to think I did 86 hours of riding on 26th.
Posted : 30/05/2009 6:19 pm
you did stop the timer didn't you
Posted : 30/05/2009 6:44 pm
Wierd. After a ride I stop the timer and then press/hold reset until it counts down. The most recent track is then available for transfer.
Posted : 30/05/2009 6:47 pm
that's news to me! I just plug the thing into my pooter when I get home and it finds the new track. Though I suppose I'll have turned the thing off which may have the same effect ?
The latest funny is that when I upload the route into Memory Map, it shows up as several sub-tracks instead of one continuous one, so I have to go through clicking "join track" to connect the parts...
Posted : 30/05/2009 6:49 pm
Sorted it was reporting date and distance wrong in agent but has worked on the site when I uploaded it.
Posted : 30/05/2009 8:37 pm
