Garmin 810 navigati...
[Closed] Garmin 810 navigation crash
Just bought a garmin edge 810 and it's great but it keeps crashing when navigating.
I'm using ordnance survey maps
Anyone else had a similar experience/solution.
Posted : 05/11/2016 9:13 pm
Do you have the latest firmware version installed
Posted : 05/11/2016 9:29 pm
No idea, I bought it used from eBay so I would assume so.
Posted : 05/11/2016 9:30 pm
my touring did that ... full factory reset via "vulcan death grip"
and a software update (to the same latest as it happened) fixed it.
not crashed in 8 months now.
try it with another card to rule out the os maps causing it.
Posted : 05/11/2016 10:05 pm
Mine does it occasionally when navigating though not recently. Classic garmin software...
Posted : 05/11/2016 10:26 pm
My 810 work fine on firmware 5.10, others swear by 5.00, have a read here and try for yourself. [url= https://forums.garmin.com/forumdisplay.php?362-Edge-810 ]Garmin Edge 810 forum.[/url]
Posted : 05/11/2016 10:46 pm
Welcome to the world of 810 ownership. They are amazing devices but the software is appalling.
If you do find a version that works then never update. Turn off auto update on your phone too.
Mine and lots of other owners crash when navigating and take a detour. Seems to confuse its self and crashes. It then seems to take about an hour to find the satellites.
It's so bad I also run strava on my phone as a backup on rides I don't want to lose.
Posted : 05/11/2016 11:34 pm
Funny isn't it. I've had about 10 Garmin devices over the last few years, not one has ever caused an issue, all kept bang up to date. Except for a driver issue with the ant+ stick when I moved to win10. That took 5 minutes to fix.
Then I sold one, edge 605, about 2 years ago. Worked for about a month, then he connected to his computer to download. Stopped worked. Kept crashing. Switching off and so on. It's not even like he was even able to update it.
Posted : 06/11/2016 8:25 am
To balance things out a little. 810 faultless, joy to use. Openstreet maps from following instructions on Drain maker Great bit of kit.
Posted : 06/11/2016 9:38 am
