Want to stick a 'fender' style guard on for our impending scottish winter gloom. Had a fitter one for my old marzochi's and a shockboard for my old RS's - however my Pikes have a capped steerer (closed off with a tiny hole only) so can't see how the normal plug in fitting will work.
Is there a product that will fit - don't really want to go down the zip tie route if I can avoid!
Posted : 05/09/2009 10:21 pm
It's a 6mm threaded hole in the bottom of the steerer tube. I use a Topeak Defender on mine. Simply throw away the plug thingy and use a 6mm bolt instead. Bit of Locktite and the job's done.
Posted : 06/09/2009 8:38 am
use a neoguard or similar. far more effective.
Posted : 06/09/2009 8:44 am
Or you can simply bolt one of the THE guards onto it using the hole in the bottom of the steerer. Works for me anyway.
Posted : 06/09/2009 9:15 am
