Front brake callipe...
[Closed] Front brake calliper adapter.. help!
[#12376352]
Mechanical geniuses out there... what new front calliper adapter mount (Shimano) do I need to order.
I changed the fork on my 2021 Ragley Big Al, previous fork was a 52mm offset running 180mm discs. The new Revelation fork is 42mm offset, I put the brakes on an took the bike for a spin. The front brake barley worked.. took it apart and only about 1/3rd of the pad is making contact with the disc. The drilled inserts in the Revelation fork are equal length, so I assume I need a mount that has equal length protrusion ?
fork
Posted : 09/05/2022 9:03 pm
Can't see the pic but does it need an adaptor at all? Modern forks often fit a 180 rotor as standard. Offset won't make any difference
Posted : 09/05/2022 9:06 pm
bike
Can you see the images now ?
Posted : 09/05/2022 9:07 pm
Pics working for me now.
I would say try with no adapter: as @nickjb says the fork is probably expecting a 180mm disc out the box.
Posted : 09/05/2022 9:11 pm
Yep, that's a 180 mount fork as standard, fit your caliper with no adapter (and shorter bolts, usually M6x20mm)and it should be fine.
Posted : 09/05/2022 9:13 pm
Many thanks, just offered it up and that seems to make sense.
Posted : 09/05/2022 9:24 pm
