Freewheel hub help
[Closed] Freewheel hub help
I've had a cracking noise coming from the rear cassette/hub when pedalling as was advised to strip and clean the freewheel hub .
Never having done this it took me a few mins to figure it out but eventually stripped it ok. It was pretty filthy so cleaned and reassembled but now have a problem , when i clamp the wheel up in the frame it won't freewheel?Is ok with the QR undone or off the bike .
Any advice welcome!
Posted : 07/06/2009 4:02 pm
What hub? ?Did you strip the bearings out?
Posted : 07/06/2009 4:06 pm
Same Q as TJ
Sounds like the cone nuts might be too tight to me.
Posted : 07/06/2009 4:08 pm
Goldtec draco hub with cartridge bearings
Posted : 07/06/2009 4:20 pm
Did you strip the bearings out? There is a exploded diagram on the betd site ( I was just looking at these today for tandem use)
My guess would be bearings not seated properly of spacers in the wrong way round
Posted : 07/06/2009 4:28 pm
Cheers , will have a look and see !!!
Posted : 07/06/2009 4:47 pm
