Freeview HD - Anyon...
[Closed] Freeview HD - Anyone got it?
Saw it advertised last night.
The HD on sky seems pretty good, just wondered if it is the same on freeview?
Posted : 20/04/2010 10:39 am
I'm tempted but going to wait a couple of months till there is a HD Freeview DVR available. No way I could go back to the distant past of actually to having to make sure I am around to watch a programme at the particular time it's broadcast.
Posted : 20/04/2010 10:42 am
timmys - they're available now...
Posted : 20/04/2010 10:43 am
wwaswas - Member
Really? I'd loved to be proved wrong but I thought it was only Freesat not Freeview ones at the mo.
Posted : 20/04/2010 10:48 am
[url= http://www.cheapelectricals.co.uk/acatalog/Samsung_DVDSH893_160gb_HDD_Full_HD_Freeview_DVDrecorder__USB_Cd_ripping__dvd-sh893__.html ]first google result for HD Freeview DVR[/url]
Posted : 20/04/2010 10:50 am
Pretty sure that doesn't record Freeview HD
It plays back HD DVDs though
Posted : 20/04/2010 10:58 am
Thats what i was thinking.
For the missus to be able to record a programme without me having to talk her through it everytime,
wwaswas - Member
It certain is the first google result, but it certainly ain't a Freeview HD DVR.
Posted : 20/04/2010 11:03 am
Play TV for the Sony PS3 now supports freeview HD, and it works as a PVR, and only costs £40! 😀
Not tried out the HD though, since there won't be any in my area untill the switch off the analogue signal next year.
EDIT: actually it may not work. It has support for HD over DVB-T (which is what British broadcasts are on currently), but apparently we will be switching to DVB-T2 for HD....
Posted : 20/04/2010 11:04 am
fair enough.
Posted : 20/04/2010 11:07 am
I was chatting to a mate who works in Richer Sounds over the weekend as I'm interested in getting a freeview HD recorder, he wasn't aware of any currently on the market but said Sagem are working on one, likely to be around £250 and out in the next few months.
Edit: IIRC he also said freeview HD was likely to be a better quality than freesat HD
Posted : 20/04/2010 11:19 am
I wouldn't take Freeview HD over Freesat HD unless I had no choice
To me - they haven't got enough bandwidth to be able to expand as they plan to
Posted : 20/04/2010 11:26 am
That's why they are switching to DVB-T2 I think, as it uses less bandwidth.
Freesat doesn't have enough bandwidth either, hence the reason it's actually broadcast as a lower resolution than Freeview.
Posted : 20/04/2010 11:30 am
BTW as I am sure you know 🙂 Freeview is not available in the majority of the UK at present? Check your post code online:
http://www.freeview.co.uk/freeview/HD
Posted : 20/04/2010 11:31 am
I'm 'experimenting' with a USB thingy for TV on my computer. Is HD possible with such a device? Or would I require a new thingy?
I've got to have a proper aerial installed etc before I even consider any proper TV system.
Posted : 20/04/2010 11:36 am
apparently yes, if its ones of the cheaper ones which use a software decoder instead of a hardware decoder.
However you need software which can decode the the new fan galled DVB-T2 and computer capable of doing this at a reasonable speed.
Posted : 20/04/2010 11:43 am
A new thingy would be required.
We have a Sony Bravia HD ready for when it arrives. Not yet here in Leeds/bradford.
Can't wait, though I doubt it'll arrive in time for the world cup.
We got it beacause that is what's coming rather than what's avalible now. Ours also does Internet TV for when they get that working. Should be good when it arrives, IplayerHD through the TV via HDMI is excelent.
Posted : 20/04/2010 11:53 am
 jim
No it doesn't, as Freeview HD requires new tuner hardware.
No thingies suitable for Freeview HD are currently available, Hauppauge are seemingly planning to bring one out by the end of the summer.
Posted : 20/04/2010 12:21 pm
I'm interested in the humax freeview HD pvr when it comes out. Father in law has humax foxsat pvr and works really well
Posted : 20/04/2010 12:45 pm
This incorrect as alot of thingies use software decoding. An old thingy can still pick up the signal you just need the correct software to decode the signal.
Posted : 20/04/2010 12:53 pm
 jim
Sorry, it is correct. Freeview HD uses DVB-T2, which requires specific hardware to receive it. If you don't believe me then try:
http://www.reghardware.co.uk/2009/11/23/freeview_hd_questions_answered/
Elsewhere in the world terrestrial HD has been implemented using H.264 on the existing DVB-T standard, which is indeed just a matter of having the necessary decoder.
Posted : 20/04/2010 10:15 pm
I can't be bothered doing the googling, but are you totally sure about that, Jim? When I was recently looking for something to work in Norway (where they use H.264 on DVB-T) I'm fairly sure I found dongles claiming to do DVB-T2.
Posted : 20/04/2010 10:29 pm
There is a PVR that does freeview HD that has just been released. Check out a company called 3view. Reasonable price and some nice features including taking the HD version of a programme in preference to the SD version. Quite tempted myself.... 500GB hard disk as well, although they do not provide a supported way to copy recorded content off the device.
Posted : 20/04/2010 10:57 pm
