After todays ride, my freehub has developed a little bit of a wobble, not much butenough to disengage the pawls every now and again when I puit the power down.
I'm running Formula hubs, to be more specific the rear is a 12x150 hub that uses a bolt through axle.
On stripping down, I've found out that the hub takes a Campagnolo style freehub (according to Park Tools website) which slides onto the axle and is held in place by the hub end caps. These are done up tight and theres no play on the axle that I can see but once installed into the hub the wobble reappears.
Long story short, I guess I need a new freehub, but where do I get one from - all the ones I've seen on CRC are for specific hubs and seem to have a different layout for the pawls. Will these fit or if not does anyone know af a dealer who would carry such a thing?
Ta in advance!
