Frame pivot bushes
[Closed] Frame pivot bushes
Anyone tried to source or fashion some frame pivot bushes ?
Any advice would be great
Posted : 27/10/2017 7:04 pm
easy enough if you know the measurements
Posted : 27/10/2017 7:06 pm
Junkyard help me out
Posted : 27/10/2017 7:10 pm
remove bearing
Get some digital vernier calipers
Measure bearings Width Inner and outer
Go to bearing shop give them the measurements
Most bike stuff does use standard bearings but there are not always cheaper - eg Hope wheels ones are dearer from my local bearing shop than from Merlin
How to guide with measurements on the side to enter data and get the bearing
https://www.bearing-king.co.uk/how-to-measure-a-bearing.php7
Might help of you say what it is for or from what bike otherwise it will be pick your size
Possible use Igus bushes if there is some "slack" - think like the top cap on your Bottom Bracket or the bush in your shock
Posted : 27/10/2017 7:24 pm
Thanks junkyard it's an old idrive main pivot bushings ...so no bearings in the pivot point
Posted : 27/10/2017 8:21 pm
