Frame bungs for int...
[Closed] Frame bungs for internal routing - help!
I have a frame that uses internal routing.
I have decided to try routing the cables externally using frame mounts and p clips less for aesthetics more for kinder cable/house routing.
The "thing" is that this will leave 5(?) holes needing plugging ๐Ÿ™„
The manufacturer does stock spare bungs ๐Ÿ˜ and have suggested I leave the open.
That's all fine and dandy but I would like to plug them.
Any suggestions?
Frame is a Giant BTW.
Posted : 11/07/2014 3:07 pm
I would use the brake and gear cables.
Electrical tape? a sticker, silicone sealant.
Posted : 11/07/2014 3:13 pm
Orange sell plugs but no guarantee they'll fit. If they're round holes on flattish surfaces there's likely to be household alternatives, a wee ebay search will probably find something
Think I'd be tempted to use a tidily cut bit of tape tbh. But not a sticker because you might mistake it for a crack.
Posted : 11/07/2014 4:07 pm
Silicone sealant if it's a white frame maybe?
Posted : 11/07/2014 4:42 pm
Sugru
Posted : 11/07/2014 6:30 pm
Could fill the holes with molten lead?
Posted : 11/07/2014 6:49 pm
Why go external???
Posted : 11/07/2014 7:20 pm
Which frame is it as quite a few have internal routing now id get the correct plugs myself
Blanking grommets, often sold for electrical/electronic work. Try RS Components or Maplins, or maybe just google it.
Posted : 11/07/2014 9:29 pm
I used the end cap off a biro, fitted the hole perfectly and has stayed in so for
Posted : 11/07/2014 9:38 pm
