Frame Bearing repla...
[Closed] Frame Bearing replacement - recommend me a heat gun
So I'm replacing the bearings on my Blur LT.
I have the bearing presses to get the bearings out but the axles are stuck solid.
I reckon a bit of heat will get things moving.
Can anyone recommend me a decent heat gun?
Posted : 26/02/2013 3:34 pm
Just use a hair dryer, dont get it too hot and melt the paint/frame.
Have you tired some releasing fluid yet ?
Posted : 26/02/2013 3:36 pm
Does "proper" releasing fluid really make a huge difference over GT85?
No harm in giving a hair dryer a try I suppose!
Posted : 26/02/2013 5:18 pm
A pan of boiling water's one of the best ways i've come across, not much chance of overdoing it and taking the paint off.
Posted : 26/02/2013 7:12 pm
GT85's a pretty effective penetrating fluid, not quite as good as plusgas but still very good.
A proper DIY heat gun would do the job, but, will be a little bit like using a piledriver to put in a nail. Don't get it wrong, you will regret it. And it'll be very easy to get it wrong.
Posted : 26/02/2013 7:15 pm
Fair do's NW.
Hairdryer plus big hammer for first attempt then.
Posted : 26/02/2013 8:14 pm
Boiling water X2.
You want a flash of heat rather than a gradual build up, and douse the parts in penetrating oil the night before not 5 minutes before.
Posted : 26/02/2013 8:19 pm
