Considering upgrading my Fox Floats to a pair of Talas forks, with the aim of being able to drop the front end 20mm to improve climbing etc.
What's the travel adjustment like on the go?? Do you need to stop to make the adjustment?
Cheers.
Posted : 09/02/2009 9:57 am
No its a flip of a switch for lowering or raising. Only thing you have to do after you've dropped the suspension is when you come to lengthen it again is flick the lever & pop a wheelie so the fork can push out.
Posted : 09/02/2009 10:10 am
Don't know if any use but Magura Laurin FCR forks have handle bar mounted travel adjust iirc
Posted : 09/02/2009 10:13 am
Excellent, sounds exactly what i'm after.
Anyone know the axle to crown length for the 100-120-140 Talas Forks?
Posted : 09/02/2009 10:15 am
