Fox RP23 BV air pre...
[Closed] Fox RP23 BV air pressure?
[#2331386]
guys, i had my shox back off mojo last week but never checked the air pressure in it an found out the hard way today up afan!!
after riding most of it with my pedaks smashing against the floor all the time my stag was over 90%. a nice fella pumped it up for me which helped loads but im 17st do any of you know how much i need to out in??
cheers
chris
Posted : 02/01/2011 8:16 pm
have a look at the mojo web site
Posted : 02/01/2011 11:05 pm
Err....no. No recommendations for pressure as it depends on your weight & the leverage ratio exerted by the shock linkage. Follow the set-up instructions & use the "O" ring to gauge how far the shock is travelling. At 17 stone I would guess you'll be at or near the upper limit for shock which ISTR is 300 PSI.
D.
Posted : 03/01/2011 12:34 am
ok cheers guys, i got 240psi in there now might try a bit more
Posted : 03/01/2011 6:18 pm
I'm 15st 9 and i have 190psi on my blur
Posted : 03/01/2011 9:12 pm
As said depends on the frame, but I think 1psi per kg is a good starting point, then work out what suits you.
Posted : 03/01/2011 9:28 pm
