Fox rear shock leak...
[Closed] Fox rear shock leaking air......... what to do..?
 jeb
Hello
Fox air (think it is a float) ....... what do ........ is it a home mechanic job?.............. -i can do a normal service job on a fox shock. Could it be just a normal sealkit change ?
Posted : 11/06/2015 10:04 am
It could be the schraeder valve. Probably the easiest way to work out where its leaking from is to pump it up to normal pressure, remove from the bike and immerse in a bowl of water then you can see where its leaking from.
If its the valve, the core can work loose or get a bit of crud in it. Remove using a valve core remover (Halfords less than £5) and clean and refit or replace the core.
If its the air can, replace the bushings and air seals. About £15 for the bits and about 20 minutes work.
Posted : 11/06/2015 10:14 am
I'd go with bigyinn's spot-on advice
Seal replacement is dead simple.
Posted : 11/06/2015 10:18 am
