Hey I have a 2013 fox rear shock with the CTD I usually just leave it on trail but during a steep climb i tried to change it with no luck. I got home and gave it a good clean which fixed that but the rebound knob is still stuck it moves a little left and right. any ideas or am i best to send it of for a service? Many thanks
Posted : 21/04/2015 3:56 pm
There is some grit caught in the little bearing seat so it won't ride past.
Take it off, clean and I add a bit of slick grease to stop it happening again.
Not sure if you could spray wd40 on there or if it would affect the seals.
Mine use to do it (riding in grit /sandstone).
Posted : 21/04/2015 5:41 pm
Hey thanks for your help i removed the rebound knob and theres a pin which the knob attaches too but i couldn't see a bearing?
Posted : 22/04/2015 12:49 am
