Fox forks from 80mm...
[Closed] Fox forks from 80mm to 100 or 120mm?
Hello all. I've seen some mint 2010 Fox forks that I fancy but they're 80mm when I need 100mm or 120mm. I know you can space longer ones down so can you do the same up?
Posted : 21/03/2013 6:12 pm
In a word No. You can only go shorter from a longer length.
If they were originally a 120mm say then you could but that is unlikely.
Danny B
Posted : 21/03/2013 6:16 pm
Bugger! Thanks for the quick reply.
Posted : 21/03/2013 6:19 pm
That's spot on, if they're 80's then they're always 80's, unless of course as mentioned they've been reduced down already in which case the spacers can be taken back out.
Posted : 21/03/2013 7:27 pm
