Has anyone had the paint bubbling up on their 2011 Fox Fork where the crown and the head tube meet?
Underneath the crown where is meets the base of the tube is all bubbling up and also above the crown also where it meets the tube.
Is this a common fault? Fork is a 2011 32 Talas RLC Fit Kashima.
Looks like I'll be phoning Mojo on Monday.
I've always found the paint on Fox forks to be quite durable. Are you sure they haven't had brake fluid spilt on them?
Hi, had the same issue, spoke with mojo who cited using my bike on the road and road salt. Basically telling me I'd not cleaned them well enough. Mine are 2010's you may get a different response seeing as your's are newer
Sounds like corrosion under the paint to me, road salt is deadly and gets in all the nooks and crannies, i road my mountain bike to work last year and the roads were very slushy i work in a shop so gave it a good wash when i got to work to try and get rid of the salt by the end of the day the chain and cassette were rusty as hell, last time i did that.
Other wise your sweating to much and sweat is equaly bad at corroding your nice parts.
Definitely not brake fluid.
I'd be surprised if it was road salt - I use a Fender Bender so get very little spray under the fork crown. Also I don't commute on the bike or anything like that and tend to be a bit of a mentalist about cleaning it especially in Winter.
I'll see what they say on Monday.
Sent the fork to Mojo to look at on Tuesday. I just called them to check they'd received it OK and have been told it's already on the way back to me complete with a new CSU. That's awesome warranty service.
A massive thumbs up to Mojo from me.
