Fox Floats 140mm to...
[Closed] Fox Floats 140mm to 150mm?
Can you alter the travel internally or do they use different internals and stantions for the 150mm's?
Posted : 16/02/2012 9:39 pm
Bump!
Posted : 16/02/2012 11:05 pm
They can go down in travel from factory setting; but not up, I believe. Exceptions being the F29 and 831 models.
Posted : 16/02/2012 11:10 pm
......some OEM forks are speccced with a reducer by the manufacturer to balance a full sussers front and rear suspension. This was certainly the case with the 2007 Stumpjumper 120, the Fox fork matched the rear of the bike in travel but was infact a 140mm Float with a 20mm reducer fitted - it was removed by many people come the first service.
We are talking 32's and not 36's right? 150mm 32 Floats are a more recent fork but if your Floats came on your bike (or were an OEM fork you picked up somewhere else) and your bike is a full susser and they are quite a new model year fork then they may be reduced 150mm forks but I wouldn't hold your breath.
If not then I think longer internals and stanchions will be required so for 10mm it's probably not worth it.
Posted : 17/02/2012 12:43 am
Get 150 and shorten. Gives you flexibity to go down to to 100 if you want.
Posted : 17/02/2012 10:44 pm
