What roughly are you running in your x2?
I know its all personal preference etc but just seeing if mines is about the ball park figures...
Im just under 12 stone and at 180psi
Giant Reign (200x57mm shock, 160mm travel), 15stone in riding kit, 220psi (2 volume bands)
Totally depends on the bike. Different leverage ratios require different pressures.
Base it on what you need to get the manufacturer's recommended sag, then tweak it for personal preference.
Three spacers, 14.5st and 185psi (roughly)
yeh I know its all about the bike/ratio etc/weight etc but just wanted to see if I'm roughly where I should be weight wise
its a vpp, 165mm bike for reference
Also 165 VPP (nomad). I weigh 11 and a bit stone without kit. Run about 160. Can't remember where I am up to spacer wise since it went back to mojo for a new air can. You are in the right ballpark.
Great cheers bella thats good to know then thanks
