Fox Float volume re...
[Closed] Fox Float volume reducers?
I'm having bottom-out issues on a fox 100mm rear shock so its been suggested I need to fit a bigger volume reducer.
There seem to be several different kits available. What on my shock do I need to measure to work out which kit I need? Can I work it out just from the shock model?
Does anyone know if you can get the kit for less than £40...?
Posted : 02/11/2016 3:07 pm
Post a photo of the shock. I've got the kit for an rp23 / CTD you can have for a lot less than that.
Posted : 02/11/2016 3:46 pm
Depends on the shock
•FLOAT DPS (9mm shaft) Air Spring Volume Tuning Kit: PN 803-00-802
•FLOAT X (1/2in shaft) Air Spring Volume Tuning Kit: PN 803-00-827
Guessing this is yours
•FLOAT RP Series (3/8" shaft) Air Spring Volume Tuning kit: PN 803-00-612
Check spacer compatibility here
http://www.ridefox.com/help.php?m=bike&id=568
£33.00... 😯 the robbing bar stewards, would take the offer above.
Posted : 02/11/2016 3:48 pm
Sorry, this took me a couple of days.
I'm guessing it's an RP3...?
[url= https://c1.staticflickr.com/6/5461/30138826584_6d6188c49e_n.jp g" target="_blank">https://c1.staticflickr.com/6/5461/30138826584_6d6188c49e_n.jp g"/> [/img][/url]
@simons_nicolai-uk - if you've got a kit could you drop me a line? edward.rollason[at]hotmail.co.uk
Thanks
Ed
Posted : 04/11/2016 12:30 pm
I don't know if this is good practice but in the past I've done volume adjustment on fox shocks by blobbing in shock grease instead.
Posted : 04/11/2016 1:17 pm
@Northwind - shock grease? Do you have a link to something suitable? I'm a newbie on rear shocks...
Posted : 04/11/2016 2:14 pm
