Fox Float shock- ca...
[Closed] Fox Float shock- can you change the compression tune yourself?
 hora
Is it possible?
Posted : 14/06/2012 9:26 am
If you've got access to pressurized nitrogen...yes.
Posted : 14/06/2012 9:29 am
Boooooom ๐Ÿ˜€
Posted : 14/06/2012 10:03 am
no, but you can add volume spacers to make it ramp up more (assuming it's more you want), it's not the same as changeing damping, but it is cheeper.
Posted : 14/06/2012 10:07 am
 hora
This is what I want. There must be a shim adaption on google- will have a look ta.
Posted : 14/06/2012 10:10 am
http://richardcunningham.pinkbike.com/blog/How-to-Install-a-Fox-Air-Volume-Spacer.html
You can get the spacers from Mojo and Loco, or you can make your own - i read that someone had made some out of an old cd case, i used a medium spacer (i'm 14st) for the rp23 on my Five to stop it bottoming at the correct sag for me (30%).
Posted : 14/06/2012 10:16 am
 hora
Perfik. Ta guys.
Posted : 14/06/2012 10:17 am
I read that you can use grease in the air chamber. Never have myself but I do add a good dollop when doing an air can service.
Posted : 14/06/2012 10:19 am
Surely some suspension oil in the air chamber would do?
Posted : 14/06/2012 11:17 am
The grease trick really does work! Find the thickest grease you've got (I use Fuchs Renolit) where you put the spacer as in the PB article, but it only lasts for a week or so until it eventually gets displaced then squeezed out past the main seal.
I've not gone any more scientific than my normal 'lets chuck an inch or so in and see what it feels like' approach
Extra float / equivalent just moves around and doesn't do anything (although yes it reduces the air volume, the plastic doesn't compress), which is why you need a proper spacer which you can clip into the correct place.
Posted : 14/06/2012 10:15 pm
