Fox Float servicing
[Closed] Fox Float servicing
Hi all,
Im going to give my Fox Float forks a bit of TLC and put in some fresh seals and oil. Ive found a service manual and the relevant oil levels but I just have one small query...
Should any old oil be cycled out of the damper cartridge prior to reassembly? Im guessing I should but just wanted to make sure...
Thanks in advance, any help is much appreciated.
Posted : 05/07/2011 2:40 pm
yes, cycle the damper to remove all the oil.
I always give the insides of the legs a good squirt with degreaser and a thorough rinse to get all the old crap out the bottom (remove the bottom out thingys first).
Posted : 05/07/2011 2:43 pm
Spot on, thanks for that. The manual does not mention it thats all.
Posted : 05/07/2011 2:46 pm
Have a look on this thread, foxyrider posted a couple of good links - I've followed the Enduro fork seals one and it's pretty good.
[url= http://www.singletrackworld.com/forum/topic/home-service-talas-forks ]http://www.singletrackworld.com/forum/topic/home-service-talas-forks[/url]
Posted : 05/07/2011 2:50 pm
Yeah, if you pump it a few times the oil comes out. Hardest thing is pressing the seals in place all the way, requires some force. The rest is easy, I just followed the service manual on the fox website.
Posted : 05/07/2011 3:08 pm
