Fox 36 Talas RC2 fo...
[Closed] Fox 36 Talas RC2 forks which version to buy 2008 or 2009 ?
Can get the 08 version for about £130 less than the 09 version - is it worth stumping up the extra cash for the 09 version?
or is it a case of you would not be able to tell the difference when riding, marketing hype, etc, etc.
Posted : 15/06/2009 6:12 pm
or you could get the 010 model, supposed to be further improvements, this also means 09's should start being discounted.
Posted : 15/06/2009 7:20 pm
 hora
True. As above. I looked into the 08's v the 09's. The 08's were £580 but they dont have the improved dampening that the 09's got. They do have FIT- just not the same dampening circuit. Apperently this helps against brake dive etc.
Posted : 15/06/2009 7:22 pm
thefallguy - Member
I there anyone in the UK selling 2010 Fox 36's yet?
I've seen 2010 Fox 40's but no 36's yet.
Posted : 15/06/2009 8:30 pm
buy once buy right
go for the 09, as said above, for improved damping and also the forks pop up from 100mm travel to 130m/160m travel much quicker than on older models, which when your doing a transition from climbing to descending is much quicker/easier.
As to whether you'll actually notice the difference on the improved damping depends on how hard you ride them I suppose.
Posted : 15/06/2009 8:54 pm
