Fox 36 talas rc2 20...
[Closed] Fox 36 talas rc2 2010- what size brake disc?
I've got a set of these on the way but can't find any info on what size brakes the post mount is set up to take. I want to fit my 203 disc, will I need an adaptor for my caliper?
Posted : 29/05/2012 10:35 pm
I have an 2011 which only take a 203 or 210 disk.
203mm = no adapter, just bolt on the post:post calliper and away you go.
Posted : 31/05/2012 7:47 am
Thanks crotchrocket, I'm hoping the 2010 is the same then.
Posted : 31/05/2012 8:43 am
Not sure that's right, I've got a 180 rotors on my 2012 160 36s with an adapter to space it out from the mounts. I think you can fit as small as 160 on them, but I think the 180 36s are limited to bigger rotors.
Posted : 31/05/2012 9:00 am
My 2010 Talas R were 160 PM, needed an adapter to fit my 180 discs.
Posted : 31/05/2012 9:08 am
mine [i]are[/i] 180mm talas
Posted : 31/05/2012 2:04 pm
you will need a post to post adaptor, I'm running 203 rotors with magura brakes and I'm using a Magura QM-26 PM7-203.
Posted : 31/05/2012 4:29 pm
Thanks all, I can confirm that the forks have a 160 post mount as standard. 203 adaptor picked up and fitted for the test run tomorrow.
Hope these forks bed in quickly, they're not very plush when initially pushed-'stiction'? Not something I've felt before with brand new RS Revs.
Posted : 31/05/2012 5:16 pm
[hijack] has anyone noticed that the lower brake mount hole is shallower than expected? The same (longer to fit a +20mm adapter) bolt that I used with an RS Reba has had to be shortened by around 12mm to work with my 36. Seems a tad odd [/hijack]
Posted : 31/05/2012 5:19 pm
225mm on my '09s
Posted : 31/05/2012 6:01 pm
