Fox 36 service
[Closed] Fox 36 service
3 Users
Servicing my fox 36 rc2 fit. Using a tftuned 36mm service kit with the skf seals.
Should the foam rings fill the whole gap between seal and fork?
They aren't as tall as the gap is, about 3-4mm short... They are the same size as the ones that came out though, so I'm sure its fine, just wanted to check, I've only serviced revelations before and remember them being more snug...
Posted : 20/08/2013 10:47 am
Have you soaked them in float fluid or whatever first?
Posted : 20/08/2013 10:49 am
Yea they were well soaked
Posted : 20/08/2013 10:58 am
Also, should I be using a proper seal press? Always used a socket and never had an issue...
Posted : 20/08/2013 11:09 am
There is a gap between the bottom of the seal and the top of the foam ring on my 36's.
I machined up a tool to press in the seals, but if you've got a suitable socket it should work just fine I reckon.
Posted : 20/08/2013 12:03 pm
