Fox 36 / pump probl...
[Closed] Fox 36 / pump problem
[#4031307]
Just building up a new bike
Got fox talas 36, when I went to adjust the air I notice 1 pump would take the up about 40psi, is that normal?
Iv r/s revs on the hardtail and it takes a lot more 'pumping' to get 40psi
Also when I disconnect the pump from the fork I'm loosing all the pressure
Hope it's a problem with the pump and not the forks, it's a halfords jobbie but has worked fine on the revs, normal screw on valve, is there different fitting for shock pumps?
Cheers for any info
Posted : 02/06/2012 2:55 pm
have you screwed it on enough to open the valve? and not just filling the space between the valve and the pump?
Posted : 02/06/2012 3:08 pm
This happened to be on thursday on my rp23 shock, i just replaced the valve with one from and inner tube, works fine now...
Posted : 02/06/2012 3:11 pm
Yeah screwed right down...
How did u replace the valve?
Posted : 02/06/2012 3:19 pm
With one of these http://www.trialsuk.co.uk/products/valve-extractor
Posted : 02/06/2012 3:20 pm
just take it to your LBS, for me they did it for free.
Posted : 02/06/2012 4:55 pm
Ok borrowed a mates fax pump and it's fine with it!!!
Mine works on the revs and the rear shock on the new build.... Weird, but seems like I can ride the new bike in the morning 🙂
Posted : 02/06/2012 6:33 pm
